Jamie called....
Old May 23, 2014 | 07:52 AM
  #31
UltraNutZ's Avatar
UltraNutZ
Originally Posted by sanman4ever
Please provide a recommendation for with a brand and model number. Thanks
IMO
2:1 - D&D Fatcat if you can deal with loud.
2:1:2 - Fullsac DX pipe and a set of Rinehart 4" slipons.
exhaust are about as subjective as oil threads are. but for performance, I think it's hard to beat the above.
Old May 23, 2014 | 07:54 AM
  #32
Keithhu's Avatar
Keithhu
Originally Posted by ThisIsMe
Keith,
Thanks for the info and to be honest this is exactly what I needed as far as info. I am looking at the 107 kit from Fuel Moto. I really like the sound and look of the true duals and heard of the performance loss because of such. Your numbers are exactly what I need to see to make my decision.
Although the HP looks low, the torque looks acceptable and that is really were it counts on a bagger. I had 120lbs at 3k rpm and 100hp stuck in my head with true duals. Looks like with the 107 kit I was looking at and another batch of money for the CNC heads will get me there. Darn this internet thing and budgets.
Is the sound and look of the true duals worth the performance hit in your eyes?
Thanks again
I went from a Fullsac 2-1-2 to true duals entirely for the sound. I love the sound!
I was aware that duals would cost me a bit in performance, but I really wasnt really prepared for Jamie to recommend *against* ported heads with true duals. Had I been aware of that I might have stuck with the Fullsac setup, but at the time I changed to true duals a 107 kit was not on my radar screen.
I was close to buying yet another exhaust setup - Jamies stainless 2-1, and also add ported heads but that would have put me over $5K and at some point you just have to stop. Jamie was out of his stainless 2-1 and I took it as a sign.
So it goes to show you that planning ahead is valuable - in real terms: money and performance. If you're not able to or dont plan well, you wind up having to make decisions - do I spend more money to replace what I've already replaced once, is that additional money worth it, etc etc.
But as most things in life, things change and you cant always go on a straight predicted line.
And again, there are more things to my build than just numbers, and for me its also about reliability.
I could have saved about $1K by sticking with bored stock jugs and not refreshing the heads, but I wanted that reliability, and also the valve clatter is gone, so well worth it - *for me*
Old May 23, 2014 | 07:56 AM
  #33
ThisIsMe's Avatar
ThisIsMe
Originally Posted by evil451
this may sounds stupid but what the heck, we are on the topic.
If true duals suffer from being too free flowing, wouldnt adding torque cones just take care of the issue?
I have heard they work but also hear the back pressure needs in alternative timing for best performance. That being one cylinder finishing the exhaust stroke while the other is starting. Then the pressure would be off and then sort of free flowing.
By all means I am no expert in the matter, just relaying what I hear.
Old May 23, 2014 | 07:58 AM
  #34
Keithhu's Avatar
Keithhu
Originally Posted by UltraNutZ
IMO
I'd also say stick with what your builder recommends (or whats in the package if you're doing the work and buying a package).
So if you're going with Dragos, get his setup, Fuel Moto, their 2-1, etc. They've likely been extensively tested together, and at least in Fuel Moto's case, a lot of design and performance testing went into his pipes.
Old May 23, 2014 | 08:07 AM
  #35
glider69's Avatar
glider69
d&d fat cat is an awesome exhaust and it makes great power. fit and finish is second to none too. this is coming from personal experience and i've ran true duals and a few other 2in1 setups.
Old May 23, 2014 | 08:09 AM
  #36
ThisIsMe's Avatar
ThisIsMe
Thanks again. I am hooked on the true dual sound as well. Read after I posted what was mentioned about the ported heads. Guess I can save on the heads and rest on numbers like you have. I have an 07 so my true duals are limited. But this info will surely help.
I think when I get closer to pulling the trigger, I will call over there to see what they recommend on the true duals. I see the Supper Traps on sale for $381. Wonder how they will do.
Old May 23, 2014 | 08:12 AM
  #37
UltraNutZ's Avatar
UltraNutZ
something else to look into although I haven't had mine put on the dyno yet. The Rinehart Slimline Duals. It's not actually a dual but more of an "H" pipe. I put this on a couple of weeks ago and the very first thing I noticed was the equalization of sound and pressure at idle to be more like a true dual.
Old May 23, 2014 | 08:50 AM
  #38
2013_FLHTK's Avatar
2013_FLHTK
"valve clatter is gone" What is the key to losing the clatter?
FYI... That torque curve would fit my riding style like a glove.
Old May 23, 2014 | 09:06 AM
  #39
Primetime_2's Avatar
Primetime_2
after I scheduled my build I found out my Rinehart 2-1 develops a tourque dip in the 2k rpm range. I emailed Jamie and he said some rinehart 2-1 designs had this issue because of where the 2 pipes combine there is some blockage design in the pipe. Well after tearing mine down and inspecting it was determined mine was not that design so I got lucky you could say. I told Jamie before I left from dropping off the bike, if my pipe has that blockage to replace it with a pro-pipe, I didn't drive 4 hours one way to have a torque dip
My brother had his build with cobra tru dual heads and bassani slip ons. cobra tru dual heads are 1 3/4" straight through i believe and he cut his baffles down to about 7". his produced slightly more torque than mine and 6-7 hp less than mine. Identical builds otherwise. I think the design of the true duals that take a sharp bend out to the left side of the bike are just fine for making good power. MGS head pipes are the same way but i think they are stepped from 1 3/4"-1 7/8"-2" and they claim some fantastic gains
Old May 23, 2014 | 07:42 PM
  #40
ThisIsMe's Avatar
ThisIsMe
I think I looked at them as well. To be honest I have not seen a cross-over pipe or h-pipe on the brake side that appealed to me. I am on a 2007 so most of those are out, as they sneak back under the frame, which I have only seen on the 2009+ ultras.
