Screw ?????
Old May 22, 2014 | 06:34 PM
robfaulkner's Avatar
robfaulkner
Default Torx sheet metal screw....
Have you got an ATV or snowmobile (if you live in the south, no sled I'm sure!!)? Those types of screws are common on them.
Old May 22, 2014 | 09:51 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Headlight to assembly to outer fairing?
Old May 22, 2014 | 10:00 PM
TUCCI's Avatar
TUCCI
I don't think it's off your bike, most screws I've seen on my bike do not resemble anything like your pic. I wouldn't sweat it.
Old May 23, 2014 | 01:22 AM
jerryt87's Avatar
jerryt87
Originally Posted by QC
Did you check to make sure your Flux Capacitor is still attached?
Most likely from a broken catalyzer.
Old May 23, 2014 | 02:08 AM
Potato_Potato's Avatar
Potato_Potato
Check the screws that attach the saddlebag hinges to the bags & lids.
Old May 23, 2014 | 02:30 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
My guess is it's from the bracket, bolted to the frame, that a similar brake light switch to this part mounts to. Lower right in front of rear wheel. (Follow brake line back from rear master cylinder) Also a similar one on the ring clamp that attaches the rear rubber flex brake hose to the frame on the rear caliper.
Old May 23, 2014 | 03:19 AM
Wardenbf's Avatar
Wardenbf
Default Screw
I'm pretty certain that there's supposed to be a loose screw that goes between the handle bars and the seat. I've been told there's one on my bike.
Old May 23, 2014 | 04:01 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I would check the tires. You may have pinched this screw in a thread and taken it into the garage.
The chrome decor under the passenger foot board is held by two of these screws (on mine). The tip of the screw is not used in this case.
Old May 23, 2014 | 04:52 AM
lp's Avatar
lp
Check inside the fairing. Speakers maybe if you have them? Maybe too big for that. I dunno.
lp
Old May 23, 2014 | 05:09 AM
Iceman24's Avatar
Iceman24
Are you sure someone (i.e. OL or riding bud) isn't messing w/you? They could be watching your endless effort(s) to find the place for this unnecessary screw...??
