curious ,hours
Old May 23, 2014 | 09:44 AM
berndog's Avatar
berndog
Default curious ,hours
Im curious,how many hours should it take for an average mechanic to change cam chain tensioner shoes ,cam bearings ,and re & re rocker boxes?
Old May 23, 2014 | 10:12 AM
Sanyasi's Avatar
Sanyasi
Denco----SE hydraulic cam plate & Hi flow oil pump
Quick Install push rod kit
99-06 T/C inner cam bearing
cam bearings
roller bearings
fuel filter kit
TC cam spacer
Labour 8 hours on a 2003 Electra Glide Classic with 60,000 kms.. I also went out to Jarz and picked up the Baisley pressure relief piston and spring and had Denco change the SE one for this.
Old May 23, 2014 | 11:30 AM
jlgale's Avatar
jlgale
Default Curious, hours
Harley has a manual which tells the mechanic how long something should take, that is usually how most shops give you the labor cost. Most HD shops follow it even if the process is done in less time.
Old May 23, 2014 | 11:58 AM
0ldhippie's Avatar
0ldhippie
Flat rate to replace cam support bearing/cams/secondary cam chain/tensioner is 4.3 hours. Cam bearings would add about .4.
http://www.allbookez.com/pdf/l6hwp/
Old May 23, 2014 | 12:15 PM
Veekness's Avatar
Veekness
For a guy not accustomed to this work, I think it safe to double the factory flat rate... Also, if you get the adjustable pushrods, you can easily knock an hour plus off the time. When and if I do this job (will probably have my Indy do it) I'll get adjustables...
Rogue8Man
Oct 26, 2014 06:08 AM
LeFat1
Exhaust System Topics
26
Apr 28, 2013 01:21 PM
8828alex
Jan 29, 2013 07:20 AM
HD Roamer
Mar 16, 2011 12:45 PM
rags
Oct 31, 2009 02:34 AM
