Compensator
Old May 27, 2014 | 01:27 PM
skiddd's Avatar
skiddd
Default Compensator
I did a search and came up empty. I need to know what year Harley made the Screaming Eagle compensator stock(on all bikes, touring, dyna's, softail, etc....) thanks.......... I know the new 2014 compensator is available so I might go with that one............ thanks in advance........
Old May 27, 2014 | 02:33 PM
btsom's Avatar
btsom
The '11 Touring bikes got the then current SE comp from the factory. Can't help you on the others. There have been 2 revisions since then. First revision was ONLY the thrust washer modified with oil slots on the compensator side, all other parts unchanged. '14 is the full revision. As far as I know, no parts are interchangeable with the pre-'14 units. The '14 comp kit is aimed at the '11 and newer bikes and does NOT include the revised rotor made necessary by the change from a coil spring to the belville springs. If the factory comp on a pre'11 bike is replaced with the '14 unit, a new rotor must be purchased separately.
Old May 27, 2014 | 02:35 PM
skiddd's Avatar
skiddd
Cool, thanks for the great information. I appreciate it very much........... Ride safe.
harley_jeff
Engine Mechanical Topics
Jun 14, 2018 07:16 PM
Wormy
Jul 31, 2017 09:17 PM
tenn.vol.
Aug 2, 2016 06:51 PM
soft 02
Sep 29, 2013 06:32 PM
tennesseeguy
Aug 27, 2013 05:18 PM
