Jackpot 2-1-2 X-Over question
Old May 29, 2014 | 02:00 AM
SmokeyJoe101's Avatar
SmokeyJoe101
Default Jackpot 2-1-2 X-Over question
Hi all - I just installed the Jackpot exhaust with the full size XOver pipe.
Question is: I only have about a 3/8" clearance between the pipe and the belt, is this normal and is this enough?
I did two of the heat cycles so far, and if the idle is any indication of how this is going to sound then all I gotta say is WOW!!!
Old May 29, 2014 | 04:43 AM
'05Train's Avatar
'05Train
It's close. Keep your belt tension in spec and it'll be fine.
Old May 29, 2014 | 05:18 AM
SmokeyJoe101
Do you have this setup as well?
Old May 29, 2014 | 06:45 AM
skydude426's Avatar
skydude426
The stock crossover is close as well. Especially when the bike is on a lift and the swing arm is all the way down.
Old May 29, 2014 | 07:09 AM
'05Train's Avatar
'05Train
I do. I think my "problem" is exacerbated a bit by the JRI rear shocks which sit the bike up a bit higher (which puts the belt closer to the crossover).
Like I said though, just keep the belt tight and there's no contact.
Old May 29, 2014 | 07:28 AM
SCJE8's Avatar
SCJE8
I just installed the same setup...very impressed at this point.
I have about 3/8" clearance as well...but it's fine. It is at the bottom of the swingarm travel and it won't get any closer...and the OEM clearance is not much more than the 3/8".
Steve
Old May 29, 2014 | 07:38 AM
SmokeyJoe101
Good to hear, I did not pay attention ot how close the belt was before removal.
DevilSperm
Aug 6, 2019 04:45 AM
Dewking
Jul 14, 2018 08:19 PM
sharps45100
2014-2024 Touring Models
26
Mar 23, 2017 08:18 PM
chief1600
Sep 3, 2014 11:31 AM
Hog_fever
Sep 16, 2006 06:28 PM
