dyno tune question
Old May 30, 2014 | 01:52 AM
bklynbob's Avatar
bklynbob
Originally Posted by 0ldhippie
If your service manager didn't suggest a dyno tune with cam install I'd run!! Anyone insalling performance cams and not recommending a proper dyno tune shouldn't be in the business. Do some searching for a good tuner in your area and have a proper tune done.
Oh yeah.......
Old May 30, 2014 | 05:55 AM
glide2005's Avatar
glide2005
I had cams and head work done on my bike with the TTS tuner. My indy referred me to a tuner that he knew that can tune the bike with his laptop. He tried three times to get it right. I road from just North of Houston to Dallas for a dyno tune. After the tune, there was 11 more hp and 10 lb tq more. Enough to make a world of difference. Get it dynoed.
Old May 30, 2014 | 11:59 AM
LXProspect's Avatar
LXProspect
6th Gear
Thanks for all your thoughts fellas. I've decided to do a bit more searching to find a different service shop. My bike is my pride and joy and want nothing but the best for it... (as most of us on here feel). Thanks again!
Old Jun 3, 2014 | 08:50 PM
sanman4ever's Avatar
sanman4ever
Originally Posted by '05Train
Then the tune's not right. Which is why it's not really smart to trust a tune from a stranger on the internet who hasn't developed the tune on a dyno.
Remember, there's much more to a tune than the peak numbers.
I'm curious to see what your thoughts are on the difference in feel.
Results are in......tuner said the canned map I had really wasn't that bad but it was to rich and was breaking up.
So here's the numbers before and after:
75.2hp@ 5360rpm & 92.4ft-lbs@ 2721rpm
VS
79.5hp@ 5293rpm & 100.7ft-lbs@ 2824rpm
Throttle response is much more crisp. I also was getting popping when starting but that is gone. Idle is very smooth as well.
What do you guys think?
Old Jun 3, 2014 | 09:18 PM
dochawken's Avatar
dochawken
VS
put an Andrews 57 in that ride....great improvement in all areas. Not sure what tuner you run...but after my cam unstall I went to 96 hp and 112 trq...TMax tuner...
Old Jun 3, 2014 | 09:20 PM
sanman4ever
I'm running TW222's with a PCV. Also have true dual so there's some limitations there.
Old Jun 4, 2014 | 04:25 AM
'05Train's Avatar
'05Train
VS
Looks good!
Old Jun 4, 2014 | 05:27 AM
jrdfatboy's Avatar
jrdfatboy
I don't know what part of Wisconsin you are located, but if you can get it to Kutter in Janesville you won't be sorry. Just had cams installed by them with a Dyno tune. Wow, what a difference, then you are done, no jacking with a portable tuner just ride.
Old Jun 4, 2014 | 07:10 AM
sanman4ever
Looks good!
You think? I was disappointed with the HP results on paper. Probably the true duals holding back the HP numbers?
Old Jun 4, 2014 | 07:34 AM
evil451's Avatar
evil451
Seems low but what do I know... I dont think the true duals are that big of a loss.. a little but not that much. You should be well over 80 hp I think
