800 miles later
Old May 30, 2014 | 08:19 AM
Pondskipper's Avatar
Pondskipper
Default 800 miles later
I had the transmission out a couple of weeks back to replace the main output shaft bearing, there was so much on the drain plug it was crazy, while I was there I swapped the IPB for an upgraded All ***** bearing and race.
800 miles later and the transmission is perfect, smooth shifts, no grinding or scraping noises that apparently only I could hear, no leaks, at 42,000 miles I can hear fifth gear whine for the first time. All other bearings, shift forks etc were good, I also put 75/110 gear oil in there as well as we are getting into the hot weather. Glad I caught this before a catastrophic failure, when I pulled the output shaft the bearing split and spilled its guts into the case.
Bought the specialist tools from George's Garage, great quality and service from George.
13RoadKing
Feb 4, 2017 11:38 PM
geezerglide04
Sep 12, 2014 08:20 AM
trackadaptor
Dec 5, 2012 06:43 PM
Guntoter
Apr 13, 2012 12:34 PM
bigjohn1percenter
Nov 13, 2009 07:05 PM
