Need help!! Broke down
Old Jun 21, 2014 | 12:53 PM
  #41
2AMGuy's Avatar
2AMGuy
Community Influencer
Originally Posted by checkers
I didnt read complete thread, but loose or dirty battery cables or battery took a dump. If you haven't checked these, it is the first place to go.
U betcha!
Always check the simple, cheap stuff first.
Old Jun 21, 2014 | 12:59 PM
  #42
TheGrandPoohBah's Avatar
TheGrandPoohBah
Great news! Glad you are going.
Keep check for a leak at the pesky O Rings!
Wasn't it nice (Back in the day) when you could see in the inline fuel filter and see fuel...
Old Jun 21, 2014 | 01:00 PM
  #43
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by TWIN CAM 96
Fuel line quick release o ring same as oil drain plug o ring 25 Cents could have plugged your fuel line
, been there done that and no fuel comes out of tank. Look down into quick disconnect carefully for broken "O" ring, dig it out, and use an angled tooth pick or equivalent to install the new "O" ring. With the right tool this will be easy.
Old Jun 21, 2014 | 01:05 PM
  #44
hvacgaspiping
Originally Posted by Bowhunter61
Is this on the line or the quick disconnect side?
Guess I can pull it off and look
It is on the line part of the quick disconnect. The "O" ring is a little difficult to get to unless you use something like an angle toothpick, dentist`s tool or something else of that nature. However, if the "O" ring is bad and torn up to the point of blocking flow, it should leak gas and drip onto things below where it is connected.
Old Jun 21, 2014 | 01:08 PM
  #45
hvacgaspiping
No spark on either plug, pulled the ignition coil and checked it against the manal ohm resistance measurements and the secondary and primary seem to be within spec.
Checked all connections and retightened, still no spark.
Any suggestions on what to check next????
Did you check for INPUT voltage (the two small wires to the coil)?
Old Jun 21, 2014 | 01:11 PM
  #46
hvacgaspiping
Originally Posted by Hausguy
Defective Kill Switch? Nah, too simple.
, If you don`t use your kill switch to shut off the bike, that switch could get corrosion under the contacts and not make a complete circuit. This may happen intermittently at first, and then nothing. That`s why you should use the kill switch occasionally to reduce the possibility of that happening.
Old Jun 21, 2014 | 01:12 PM
  #47
soft 02's Avatar
soft 02
OK found the problem.
Pulled the fuel pump/filter assembly and one of the lines had come off the pump. It was the bottom one (I think this is the one that comes out of the pump to the quick disconnect). Last time I had this apart was 20K miles ago to replace the filter. Maybe I didn't get the line snapped in all the way and it took this long to wiggle loose.
Put the line back on, made sure the collar snapped into place, put it all back together and it fired right up.
Way cool man! Motor on down the road!
Old Jun 21, 2014 | 01:13 PM
  #48
hvacgaspiping
Originally Posted by jetfixer62
https://www.hdforums.com/forum/showthread.php?t=971791
See page 7
Sounds similar...after towing 256 miles to a Denver dealer it was the o-ring in the fuel disconnect. It was preventing fuel from leaving the tank. I think I saw elsewhere that there are two o-rings in there and it's often the first one. Anyone that's done it that can shed light on this? I'm def keeping one of those little Bastards in my tool kit!
See my later post in this thread.
Old Jun 21, 2014 | 01:17 PM
  #49
hvacgaspiping
It would still be a good idea to replace the "O" rings in the quick disconnect, and when you do, put just a little bit of grease on them (and I mean just a little bit), so they slip right into place without binding and getting cut or nicked.
Old Jun 21, 2014 | 01:46 PM
  #50
jetfixer62's Avatar
jetfixer62
Good to know what the fix was. I'm not familiar with how that's plumbed with regard to the pressure switch, but my first instinct would have been that the pump would have kept running.
