Need help!! Broke down
Old Jun 20, 2014 | 06:10 PM
Bowhunter61's Avatar
Bowhunter61
Originally Posted by soft 02
Could check the input plug to the coil?
U talking about the end of the plug wired that plug into the coil?
If so I already. He checked those. Or is there a connection on the other side?
Old Jun 20, 2014 | 06:24 PM
steelerdude1's Avatar
steelerdude1
Just to add in a couple suggestions, check your kill switch, Check your fuel line coming from the tank, Pop off the quick disconnect and plug it back in. Also try pulling the main fuse and leave it out for 30 seconds and plug it back in.
Update us on what your outcome is.
Old Jun 20, 2014 | 06:25 PM
soft 02's Avatar
soft 02
Talking about the small wires going into the coil. Can you use you PV to turn off your compression releases?
Old Jun 20, 2014 | 06:36 PM
Bowhunter61
Ok took out fuse and waited 30 secs
No go
Disconnect quick disconnect fuel line
No gas dripped out at all, this is strange since typically when I take it off I get some fuel on my rag
Old Jun 20, 2014 | 06:38 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Fuel line quick release o ring same as oil drain plug o ring 25 Cents could have plugged your fuel line
Old Jun 20, 2014 | 06:42 PM
Bowhunter61
Manual CRs
See post above leaning towards no gas now
Is it possible on the 09's to check spark by holding the plug to the head?
Old Jun 20, 2014 | 06:45 PM
Bowhunter61
Is this on the line or the quick disconnect side?
Guess I can pull it off and look
Old Jun 20, 2014 | 08:48 PM
ndnguyd's Avatar
ndnguyd
Cracked line inside of tank. ??
Old Jun 20, 2014 | 08:55 PM
Bowhunter61
I thought about that but I thought I read somewhere on here that the fule pump would run continously if that was the case. Anyone know if that is true or not? When I turn on the ignition I here the pump turn on for a few seconds and then go off.
Old Jun 20, 2014 | 09:32 PM
beasleyiv's Avatar
beasleyiv
just for giggles, did you plug the quick-disconnect back in and crank it? I thought I heard about just doing that on another thread.
