Need help!! Broke down
Old Jun 20, 2014 | 05:17 PM
Bowhunter61's Avatar
Bowhunter61
Default Need help!! Broke down
Ok sitting on side of road
Just got gas went a half mile, in 5 th gear and bike just quits
No sputtering , no nothing
Looked at codes and I have 1016 and 1040
Bike cranks fine
Can hear fuel pump when turning on ignition
Sounds like good compression
Check throttle body connector
Any ideas??????
UPDATE: Got the bike home and working on it now. I have spark on both plugs. Can hear the fuel pump turn on but doesn't seem like plugs are getting any fuel. Took off quick disconnect and it seemed to come off really easy like no pressure in line, but eh pump is turning off after a few seconds when I turn on the ignition. Wouldn't that tell me the fuel pressure is building up at least in the pump?
Old Jun 20, 2014 | 05:20 PM
nsdhoward45's Avatar
nsdhoward45
Bike cranks fine
Any ideas??????
Got Spark ???
Old Jun 20, 2014 | 05:22 PM
yokdriver's Avatar
yokdriver
U1016 Loss of ECM Serial Data
I dont know exactly what it means but it seems to be no signal from the ecu
Old Jun 20, 2014 | 05:23 PM
Bowhunter61
Originally Posted by nsdhoward45
Got Spark ???
What's the easiest way to check on the side of the road?
Pull plug and rest against the cylinder fins?
Old Jun 20, 2014 | 05:24 PM
Pioneer74's Avatar
Pioneer74
I would pop the fuel quick disconnect off the tank and see if what comes out is water instead of gas.
soft 02's Avatar
soft 02
Check your ECU fuse and the plug to your ECU.
williamfrog's Avatar
williamfrog
Found this
U1301 Serial Data Open/High Carb
Sounds like a possible bad connection maybe at the ECM or elsewhere in the Data line on the bike. Intermittent/bad connection will set these codes.
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Power train Security Status TSM/TSSM
Old Jun 20, 2014 | 05:25 PM
SIX6ONE's Avatar
SIX6ONE
I vaguely remember a thread about disconnecting the plug (can't remember the name) from behind the air cleaner and then try to start it. Sorry, but I hope that jogs some memories for more help.
Old Jun 20, 2014 | 05:28 PM
nsdhoward45
yes pull plug wire from spark plug stick screwdriver or similar in plug wire boot and hold 3/16 or so from cylinder hear and crank motor and watch for spark jumping gap
Old Jun 20, 2014 | 05:29 PM
mkguitar's Avatar
mkguitar
sure you didn;t get diesel?
seen that a few times.
2.) pull maxi fuse.
disconnect and reconnect ecm plug- or plugs if you have some kind of tuner ( or consider bypassing the tuner and trying with out)
if you are trying to 'check spark" ...be very careful, if your plug is not fully grounded, you may blow up your ignition system
got full power? lights bright?
mike
