Flickering Oil Light
Old Jun 21, 2014 | 07:27 PM
vickers1's Avatar
vickers1
Default Flickering Oil Light
Went on a ride today and my oil light started flickering. It got to the point where it was almost solid at 70 mph but my gauge is reading correctly so I am going by that.
Could the wire at the sending unit be shorting to ground or the sending unit be bad? If so, I would think my gauge would be reading erratically. Anyone got any ideas where to look?
It's a 2012 Street Glide.
Old Jun 21, 2014 | 07:36 PM
Fatboy Brian's Avatar
Fatboy Brian
My dads bike did the same thing. The wire that attaches to the sending unit was broken. I soldiered it back and all was good.
Old Jun 21, 2014 | 07:37 PM
RANGER73's Avatar
RANGER73
Pull the wire off the pressure switch and see if the light stays off. If so the wires not shorted to ground. If it comes on it is.
If it stays off, try changing the pressure switch, as it's hard to check it for continuity at 70MPH.
Old Jun 21, 2014 | 08:36 PM
TUCCI's Avatar
TUCCI
It's got to be the wire or the sending unit, they are very basic and the wire just snaps onto a threaded bolt. When i put my PSI gauge on, I just grounded the wire and that keeps the light off.
Old Jun 22, 2014 | 07:33 AM
vickers1's Avatar
vickers1
If the sending unit is bad, why would my gauge have normal readings? Does the gauge get it's readings from somewhere else?
Old Jun 22, 2014 | 08:44 AM
RANGER73's Avatar
RANGER73
Light and gauge use different inputs.
Old Jun 22, 2014 | 09:00 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
replace the sender.... I have gone through at least 3 in the last 10 years (18K on the bike)
Old Jun 20, 2015 | 09:05 PM
vickers1's Avatar
vickers1
Well I finally changed out my oil pressure sending unit. Light still flickers when hot. Going to pull the wire off tomorrow when it starts flickering again and see if it still does it.
Hope it's a grounded wire and nothing worse.
Old Jun 21, 2015 | 01:14 PM
vickers1's Avatar
vickers1
Trying to keep this thread updated for those with a similar problem. Unplugged the connector from my oil pressure sending unit and went on a ride.
Light is still flickering. I am now thinking my wire is grounded somewhere between the light and the sending unit. I will update when I find it.
Old Jan 26, 2016 | 11:36 PM
Joe Wolf's Avatar
Joe Wolf
Stage IV
Mine started flickering on to. It stops flickering after about 25 miles into my trip to work or home. That is when my oil temperature gauge starts getting up to 170+ and I just did the oil change and it is in the full range. I got 84,000 on it today. 2012 FLHX and runs like a champ with RedLine oil
