Backrest install help...
Old Apr 3, 2007 | 03:30 AM
DAWG_6's Avatar
DAWG_6
Default Backrest install help...
Just ordered a couple of backrests for the wife and me. Can anyone give a quick 'how to' on installing these?? I bought them from someone on Ebay and I don't anticipate getting the installation instructions.
Thanks for any help.
Old Apr 3, 2007 | 08:01 AM
jbhawley's Avatar
jbhawley
Default RE: Backrest install help...
If you are getting the OEM HD backrest (rider and passenger) then here are some basic instructions and pics.
[ol][*]remove seat and both saddlebags.[*]under the seat there will be two stud bolts coming from underneath the rear fender, remove the nuts and attach the rider backrest mount to these bolts. Fasten the nuts to secure this mount. There will be a center piece on the mount that attaches closer to the battery. You might have to purchase a J-type bolt/nut for this. Any hardware store will have it.[*]If the backrest comes with the rear (passenger) mounting hardware you are set...if not get it from HD. I am not sure of the part #, but tell the parts guy that you need the passenger backrest mounting hardware for a touring bike. Seems like its about 30$ or so. If you also want a luggage rack (big luggage rack) that HW is about another 40$ or so. See my attched pic. Item 1 is the backrest hardware. Item 2 is the luggage rack hardware.[*]Use the attached pic as a guide. You might have to 'play' with the spacers to get the proper clearance to allow the backrest to fit.[*]Everythin is bolt-on, bolt-off and should line up with the existing pre-drilled holes in the frame, fender, etc.[/ol]Hope this helps.
[IMG]local://upfiles/2462/FE763BFA7B2C409B839FD7A378E4110A.jpg[/IMG]
[IMG]local://upfiles/2462/6009CE771FF1489499ED3F91C4C2468C.jpg[/IMG]
[IMG]local://upfiles/2462/8FCEC85969424012BA650CE8BF1819DB.jpg[/IMG]
Old Apr 3, 2007 | 08:04 AM
RanD's Avatar
RanD
If its an H-D backrest, there will bea bracket that comes with the kit that mounts under your seat. The tapped holes that accept the bolts for the bracket are already there. Depending on which model you got, there will be a couple of options for mounting the bracket (forward or back). The rest should be fairly self-explanatory from there. I like my back rest a lot and wouldn't be without it.
Old Apr 3, 2007 | 11:01 AM
DAWG_6's Avatar
DAWG_6
ORIGINAL: jbhawley
If you are getting the OEM HD backrest (rider and passenger) then here are some basic instructions and pics. [ol][*]remove seat and both saddlebags.[*]under the seat there will be two stud bolts coming from underneath the rear fender, remove the nuts and attach the rider backrest mount to these bolts. Fasten the nuts to secure this mount. There will be a center piece on the mount that attaches closer to the battery. You might have to purchase a J-type bolt/nut for this. Any hardware store will have it.[/ol]
Thanks a million...I couldn't figure the third mounting point out from pictures alone! I'm looking forward to throwing this thing on!
Old Apr 3, 2007 | 11:27 AM
jbhawley's Avatar
jbhawley
which third mounting point are you refering?
The backrest takes two mounting points on each side of the bike and if you put the premium luggage rack that takes two more on each side.
The middle pic i send is where the rider backrest mounts. The big plastic washers on the rear fender accept the mount and the J-nut accepts the front portin on the mount. AHHHHH. i guess that is the 3rd point you mentioned. There are some adjustments you can do on the rider backrest mount. It has 3 sets of holes. Depending on if you want more room or more passenger room.
Old Apr 3, 2007 | 11:44 AM
DAWG_6's Avatar
DAWG_6
Yeah, I'm putting on the rider backrest....I've got an Electra Glide Classic now, tour pack, etc.....so I need the backrest.....my wife loves it on the back so much, I'm thinking about selling the Road King depicted below. Thanks again for your help and pictures!
goldie
Apr 28, 2018 07:39 AM
Limit
Jun 14, 2012 11:36 AM
ON-3
Jun 10, 2009 10:24 PM
bdavis
Sep 20, 2007 05:47 PM
trmn8r
Sep 2, 2006 09:32 PM
