The information available on this and all web sites is worth what you pay for it (most of the time) With that said I seen a post last week that said de=catting a header pipe would not change back presser at all ? So if you do a search you can find any answer you like .
De-catting my stock headpipe exposed/aggravated a couple of lean spots in the factory tune. I rode it like this for about a week while i waited for my stage 1 package to arrive. Once installed, the surging and misfires went away. She now runs very smoothly.
My bike is bone stock with the stock mufflers and even the stock Harley air filter. I understand the theory on back pressure and the possible lean condition that could occur when removing designed exhaust obstructions. I plan to watch my spark plugs for any signs of bad news.
In the event that there is something going on, I will make it a priority to get new mufflers, air cleaner and tuner to finish it out. Right now, everything I have read points to the little to no internal changes when only removing the cat.
Don't get mad at Wurk Truk. He is just upset that his sheep told him it needed some space.
I asked Nightrider the maker of the VIED & XIED why you need Xied FL-XIED-10 with the cat or FL-XIED-10TFF without the cat or why they recommend a 50% setting with the cat and 25% setting without the cat on the VIED. This was the reply I got: "Generally the VIED's want settings around the 25% rich area once the converter is removed. This is actually to compensate for reversion bringing fresh air to the sensors (which is seen as a lean mixture and actually adds some fuel), so the VIED needs to be 'turned down' some to compensate. The net effect is you are still running (and adjusting) to get the ECM to run in closed loop at 14.0:1, but you have to back off on the VIED settings to stabilize the voltage readings with the lower settings because of the fresh air that can get to the O2 sensors with the converter removed" So apparently removing the cat actually makes the bike run richer not leaner as most people believe. They also recommend the FL-XIED-10TFF or running 25% on the VIED if you keep the cat in but change to slip-ons with larger then a 1.75" baffle.
Yup, I am sure a dumb ***.... what does that make some of you guys who have NO CLUE on tuning an engine?
Let's deal with XIEDS first. For a pipe swap? Not good, different pipes make for different VEs inside of the ECM. Know what a VE is? A 'tune' consists of TIMING changes and XIEDS do NOT do that, nor do they really effect open loop portions of a tune, like WOT. Pure *** snake oil and Tell Steve Mullens I said that. A $3 resistor does NOT make a $20k bike run correctly.
Removing the cat material decreases power to the bike. The scavenge effect of the pipe is ruined. The cat material does not, by itself make any less power than a true catless pipe, usually. The catless pipe WILL decrease temps appreciably. There WILL be times the EGR in a gutted pipe WILL effect a tune. Pipes work on sound waves and pressure waves. These wave go BOTH ways. The engine inhales thru the pipe. Did you know that? Without the cat material in place, it can inhale to the incorrect O2 sensor.
All you guys know is internet BS and have NO understanding of what tuning is about. All you have is you own bikes using butt dynos. Gimme a break. NOTHING scientific about THOSE methods, now is there? No dyno runs to prove your points? Same BS in the other thread. Like O2 sensors remove fuel only and an ECM can correct itself for pipe changes. Simply BEYOND ridiculous. Sigh.
And... to *******? Advertising in an open forum without you being a vendor is simply against the rules here. Don't like that? PLEASE leave this site. Or... the rules don't apply to you? Wanna keep thinking that? I will go to the shed to get you booted off of here. Try me! All you do for $125 is to rip folks off who have no clue what makes an engine run correctly.
Just bought a 2012 Road Glide. It has been modified by the previous owner and I feel that it has some flat spots in the acceleration. Although it came with (2) screaming eagle performance tuners, I am taking to a very reputable dyno tuner. His question to me was does it still have the cats? He can tune it either way, but says you will bet much better results with no cats. So ordered the fullsac sportpipe and will replace the factory catted header. Thoughts?
The dude is not advertizing a product or service. He's selling his own stock pipe for one amount and offering to decat it if the buyer wishes for additional money.
Yup, A 'tune' consists of TIMING changes and XIEDS do NOT do that, nor do they really effect open loop portions of a tune, like WOT. Pure *** snake oil and Tell Steve Mullens I said that. A $3 resistor does NOT make a $20k bike run correctly.
You aren't considering the relationship between short term and long term fuel trim and how a modification such as this can in fact change open loop fuel trim.
