I was given a SE ventilator off of an 08 touring model. When I try to put it on my 07 road king the bolt pattern is different. Does anyone know if their is a way to make it fit?
I have an 08 ventilator on my 04. You need to get the soft tail pieces to make it fit
Inside the soft tail brackets you will find the piece to make it fit. Its a round looking thing with the alternative bolt pattern. You can buy the pieces separately.
Get the parts list from inside the soft tail ventilator. The part numbers are listed, go look at 28721-10 you will see the round adapter in the picture'
This will work whether it cable or tbw.
If the A/C came off of a drive by wire throttle arrangement it most likely will not fit on a unit with a cable throttle as the throttle body is different.
