Lost throttle today
Old Jul 18, 2014 | 01:00 PM
JOW_103's Avatar
JOW_103
Same thing happened to me. The codes I generated indicated it could be a short in the throttle body wiring. Dealer ended up replacing the connector pins on the throttle body. Hasn't happened since and no codes thrown since first occurrence and subsequent fix at dealer.
Old Jul 18, 2014 | 04:25 PM
wingfoot's Avatar
wingfoot
One other thing to check. Take off your seat and make sure your ECM wires are securely connected.
It has happened to me.
Old Jul 18, 2014 | 04:50 PM
skiddd's Avatar
skiddd
Thanks Man, might as well check everything.........
Old Aug 22, 2014 | 09:18 AM
Muttleybass's Avatar
Muttleybass
I'm having the same issue. I got the bulletin, changed out all the connectors at the plug, but I'm still having the problem.
I guess the next step is to check the plug under the seat.
Old Aug 22, 2014 | 08:56 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
good thing, you can check the connectors and replace them w/o removing the tank. make sure you use some dielectric grease -- I they have updated the throttle body module -- 3 or 4 times = different part number
Old Aug 22, 2014 | 11:30 PM
floridapoolboy's Avatar
floridapoolboy
Total BS, TBW should not do this! You could get killed if this happened at speed going over a bridge, just saying......
EdsRoadGlide2017
Aug 24, 2017 08:33 AM
zz2h33
2014-2024 Touring Models
13
Jul 23, 2016 07:45 PM
Bowyerde
Jul 6, 2014 03:47 PM
Tortoise98
Jun 19, 2013 06:52 PM
Duggr
May 16, 2011 01:10 PM
