Changing Fork Oil - Couple Questions
Old Jul 21, 2014 | 09:53 PM
Juan L's Avatar
Juan L
Moderator
Originally Posted by gliderman
Well thanks for the tool link but the oil is already drained out. Seems a little too rocket science to me for HD Forks. It obviously wasn't filled properly to begin with from HD and the front end didn't explode ! Think I'll just go with the 10.5 oz and ride..
That is exactly why it wasn't properly filled, someone didn't use the right tool. If you're willing to accept the potential for disparate damping then ride on and good luck.
Old Jul 21, 2014 | 10:03 PM
fullautomike's Avatar
fullautomike
I just changed mine to the Amsoil shock therapy #10 medium, the blue stuff. 10.7 ounces is 317 ml I put in 320 ml to account for what is left in my measure. The difference is amazing! No more crazy front end dive and the ride is smoother. FYI I have 22k on my bike and the old fluid was black, with a red tint. It was originally red like ATF I think.
Old Jul 21, 2014 | 11:29 PM
Lonewolf176's Avatar
Lonewolf176
Originally Posted by smithbrl
That makes me think that taking the forks off and cleaning them out would be the best way to do it but that looks like a pretty big job to me.
I agree. The reason the fork oil is dirty is the 4 fork bushings are wearing. I have seen as much as .002 difference between the old and new. Setting the level by extracting the fluid leaves the level equal. Usually the amount of oil after setting the level is less than the amount specified in the manual. Sometimes short cuts aren't so good.
Old Jul 21, 2014 | 11:41 PM
TX_ACE's Avatar
TX_ACE
Are you guys pulling the fork tubes off the bike to change the oil?
Old Jul 22, 2014 | 04:32 AM
mikeo33y's Avatar
mikeo33y
Originally Posted by Ohio HD Guy
Why are you changing the fork oil on a 13 unless you have 50k on it. You can always use compressed air and blow out the fork tubes. When I changed my fork oil in my old bike, I didn't measure how much drain, just let it drain over night or blow it out. Fill what it calls for. Too much or too little not good.
it should be changed the day u get it home. garbage is in there from factory and not the correct amount. this is the reason your front end will ride so much better after a change weather you have 1k or 50k on your bike
Old Jul 22, 2014 | 05:46 AM
Rdgray's Avatar
Rdgray
This isn't rocket science, but I still like mine as close to perfect as I can get it. I always pull my forks off when changing oil in them. It isn't as big of a job as people my think. But I guess it comes down to you have to like working on things. I made my clamp and gauge for working on them.
Old Jul 22, 2014 | 08:29 AM
hardheaded's Avatar
hardheaded
buy an extra bottle if fork oil and put half in each fork tube. put the caps back on on pump the forks up and down a few times and drain again. now refill with fresh oil 10.5 will be fine. harley's fork oil is good.
Old Jul 22, 2014 | 10:11 AM
Leftcoaster's Avatar
Leftcoaster
There is no need to remove the forks from the bike - that's a personal preference thing. Just like using a level gauge to set the fork oil level - not necessary on these old style short travel conventional forks. No need to worry about flushing with new oil, either. When you drain it the next time it'll come out looking like brand new anyway.
As said, drain the forks and add the recommended amount and you'll be just fine.
Also when filling, pour in maybe half of the oil and slowly stroke the fork. Then add the rest. Sometimes the internals will air lock and not accept the entire amount in one pour.
Old Jul 22, 2014 | 10:18 AM
Notgrownup's Avatar
Notgrownup
Drain for a couple hours or overnight then refill, voila,,,use the 10.7oz amount.
ChromeJunkie
Aug 24, 2014 05:18 AM
eoluke
Aug 8, 2010 03:05 PM
ubreal
Jan 22, 2010 10:16 PM
aaron
May 3, 2008 06:12 PM
screwdriversm
Oct 3, 2006 03:03 PM
