I screwed up.... Please Help!
Old Apr 5, 2007 | 07:27 PM
kjunguy's Avatar
kjunguy
Default I screwed up.... Please Help!
I was installing my windshield pouch and I over tightened the windshield screw. Now the wellnut turns. Is there a quick fix for this? Super Glue the wellnut to the fairingperhaps? Thanx
Old Apr 5, 2007 | 07:29 PM
TXCHOP's Avatar
TXCHOP
Default RE: I screwed up.... Please Help!
I have used epoxy in the past with good results....If you are not a tinkerer and the fairing wont come off again for a while it should be good...If you are like me and the fairing comes off once a month, than go to the dealer and get a new insert. the new one will come with external threads as well and will stay good for a lot longer....JMOI.....
Old Apr 5, 2007 | 07:39 PM
Trailfndr's Avatar
Trailfndr
I fixrd one last week...simply pulled to bad nut out, turned it over, and screwed it back in. It held beautifully.
Old Apr 5, 2007 | 07:48 PM
SMT's Avatar
SMT
West Systems 5 minute epoxy...saved my *** a time or two!
www.westsystem.com
Old Apr 5, 2007 | 09:11 PM
EVOrider's Avatar
EVOrider
I would get the inserts from Harley. Run a tap and then take a large flat tip....then screw the insert in. The inserts are much better than the older ones. You can afford these and most dealers do carry these in stock.
fishbust
Jun 4, 2017 08:14 AM
leftyjm
2014-2024 Touring Models
Aug 17, 2016 06:22 PM
Rock Chalk
Apr 2, 2014 01:08 PM
trackadaptor
Jul 17, 2013 01:35 PM
t059736
Dec 16, 2010 03:53 PM
