compensator adhesive
Old Jul 25, 2014 | 10:38 AM
shorty07ultra's Avatar
shorty07ultra
Default compensator adhesive
I know the newest se compensator requires the adhesive MX6 something by lords. Has anyone used something else with good results and what was it. If nobody has used something else where did you get the adhesive besides the dealer.
Old Jul 25, 2014 | 02:41 PM
lewain's Avatar
lewain
Go to any auto parts store and look at their epoxy isle. There are plenty out there that will work. I went with one that had a high temp rating. "Blue Steel".
Old Jul 25, 2014 | 03:57 PM
shorty07ultra
Thanks I will check that out. Was not sure if something like JB weld would work. Not a big fan of JB but didn't even think of anything else.
Old Jul 25, 2014 | 05:45 PM
toxic's Avatar
toxic
I used a 2 part epoxy from Permatex. Permapoxy I believe it was called. Just make sure to check the heat ratings on whatever you get. I found pretty much all epoxys were good for plastic to metal but a lot of them were only good for around 150 degrees. The stuff I found is rated for 350 degrees.
47909Rider
May 20, 2013 02:25 PM
IBHarley
Oct 8, 2010 08:31 PM
amish
Jan 14, 2008 04:43 AM
waterman7474
Jun 30, 2007 12:03 PM
