I keep hitting neutral when shiftin to 2nd
Old Aug 4, 2014 | 03:04 PM
*Road King*'s Avatar
*Road King*
Default I keep hitting neutral when shifting from 1st to 2nd
I am not sure what the deal is here, but I have recently been hitting neutral when shifting from 1st to 2nd. I have Mobil 1 V-Twin oil in the primary. Is it time for a clutch adjustment, fluid change? Has anyone else had this issue.
2011 SG 15K miles
Old Aug 4, 2014 | 03:15 PM
RKZen's Avatar
RKZen
I don't use Mobil 1 but rather the HD Syn3. Never had an issue. Although I only use the heel shifter and rarely the toe.
It sometimes happens on my Sporty on the toe shifter on long rides, as I get a little tired.
Old Aug 4, 2014 | 03:26 PM
jdvorchak's Avatar
jdvorchak
Shift harder!
Most folks can't find neutral when they're looking for it. Consider yourself lucky
Old Aug 4, 2014 | 03:33 PM
103 sedona orange's Avatar
103 sedona orange
No. Yes, try shifting a bit harder.
Old Aug 4, 2014 | 03:41 PM
Ragtop's Avatar
Ragtop
Your foot is getting lazy!
Old Aug 4, 2014 | 04:03 PM
mkguitar's Avatar
mkguitar
check that your heel shifter is not contacting the floorboard pad.
this would keep the shifter from throwing the ratchet the full distance.
other than that, step on it.
if you continue to have problems than a check of the primary chain tension and clutch adjustment is in order.
mike
Old Aug 4, 2014 | 04:09 PM
Freebee's Avatar
Freebee
Originally Posted by jdvorchak
Shift harder!
^^^This^^^....Don't be afraid to snap that foot up !
Old Aug 4, 2014 | 04:16 PM
bikerlaw's Avatar
bikerlaw
Start using the heel shifter. You'll never miss second again.
Old Aug 4, 2014 | 04:19 PM
Ron750's Avatar
Ron750
When I try to go through the neighborhood quietly, that happens. Just shift harder.
Old Aug 4, 2014 | 04:33 PM
*Road King*
come to think of it, I do have my rear shifter leveled out a bit, I might try removing it and installing a tooth higher on the spline, I might be hitting the floor board. I might also be ready for a clutch cable adjustment. I installed new bars in January and have not readjusted the cable yet.
