How to have Aux. driving lights on with High beams
Old Aug 8, 2014 | 08:12 PM
scuba1954's Avatar
scuba1954
Default How to have Aux. driving lights on with High beams
I have a rare Free Mod...Yes I said Free!!! In the past it cost about $30 for an adaptor that plugged into your headlight harness so you could have your axillary driving lights stay on even with High beams. Well I took my 14 Trike in for its 5000 mile service and requested the dealer flash my ECU with the modification that allows my auxiliary driving lights to be on with High or Low beams. No problem, and they do it for free. I have never heard of a free mod from Harley. Woohoo.
Old Aug 8, 2014 | 09:09 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
This works for us, free.
Old Aug 8, 2014 | 09:19 PM
Bohacker's Avatar
Bohacker
I've seen a bunch of threads on this topic. Every one says dealer program. This is the first time I've seen this diagram. Simple, makes sense, like it, many thanks.
Old Aug 8, 2014 | 10:08 PM
Greg2012FLHTK's Avatar
Greg2012FLHTK
That wiring diagram is for the 13 and older bikes. I did that mod to my 12 Limited. You had to do that or buy the harness to do it. The 14's have the new can-bus electrical system and it is just a software setting the dealer has to change. Most do it for you at no cost if done with another service like the 1.000 mile service.
Old Aug 9, 2014 | 10:00 PM
crimson13's Avatar
crimson13
Cool thanks for the tip, do you know if this will work for the 2014 road king?
Old Aug 10, 2014 | 01:06 AM
ke5rbd's Avatar
ke5rbd
Should work exactly the same on any 14 with auxiliary lamps. I was wonder why no hear from you. !4 Roadking is why. Congrats.
Old Aug 10, 2014 | 05:26 AM
ddm502001's Avatar
ddm502001
Never understood the need for "Driving" lights with High Beams, they add only a little side vision under regular Low Beam use and if using Fog burner lamps are pretty well useless on High Beam. Fog lamps are for low visibility conditions while the High Beam isn't justified nor recommended with fog conditions, Driving lamps are just that a visibility aspect and with the High Beam on they are lost to the glare for oncoming traffic.
Old Aug 10, 2014 | 06:35 AM
RKZen's Avatar
RKZen
A friend had that done when he picked up his new RK.
Old Aug 10, 2014 | 06:45 AM
Hammz's Avatar
Hammz
Obviously you don't have Daymaker light? Night riding visibility is very much enhanced with spots & hi beam on together.
Old Aug 10, 2014 | 07:09 AM
TheGrandPoohBah
On dark country roads at night, I like all the LED Lighting I can get.
Daytime same applies for visibility...
