shifting problem
Old Aug 13, 2014 | 06:56 AM
harley7316's Avatar
harley7316
Default shifting problem
Was hoping someone might have an idea on what might be wrong 2011 street glide sometime when i shift into 2nd it feels like the clutch is not full engaged and doesnt go smoothly into 2nd and it dosent do it all the time thought maybe the clutch wasnt adjusted properly but its only happens in 2nd gear any ideas?Using castrol 80W90 gear oil says safe for motorcycle transmissions
Old Aug 13, 2014 | 10:10 AM
Nute's Avatar
Nute
Did your problem start after changing oil or has this always been a problem? Possibly the oil itself or not the correct amount.
Old Aug 13, 2014 | 01:21 PM
casique's Avatar
casique
Make sure the clutch has been adjusted correctly!
Old Aug 13, 2014 | 08:07 PM
harley7316's Avatar
harley7316
Will adjust the clutch and see if that makes a difference
Old Aug 13, 2014 | 08:54 PM
sg2007's Avatar
sg2007
Shifter arm may be loose and binding on inner primary case, shifting gets a little harder from 1st to 2nd.....I know!!
TracerBullet
Jun 7, 2019 10:01 AM
hitman1267
Jan 22, 2015 08:12 AM
Turbo Glide 1421
Aug 29, 2014 12:30 PM
gillie64
Mar 8, 2009 10:52 AM
rayhdavidson
Mar 2, 2007 03:55 PM
