Extra wire under Batwing / head light harness
Old Aug 14, 2014 | 07:19 PM
HDJIM1158's Avatar
HDJIM1158
Default Extra wire under Batwing / head light harness
Today I found a extra wire not hooked up to anything. It is on the headlight harness about 10-12 inches down from the headlight socket. I know the 2 right by the socket are for foreign bikes but this white wire is further down, with a black plug. Never noted it before. Is this "normal" or is something unplugged ??
Thanks in advance for all advice, Be Safe JIM
Old Aug 14, 2014 | 07:48 PM
WEINERDOGBONE's Avatar
WEINERDOGBONE
Same way on mine. I used it to power my cigarette lighter which allows me to run my gps off of it without blowing fuses as it had previously.
Old Aug 15, 2014 | 10:10 AM
edpnjax's Avatar
edpnjax
I use it to provide switched power for a GPS.
Old Aug 15, 2014 | 10:21 AM
Nostalgic07's Avatar
Nostalgic07
Extra accessory wire...I used it to "power-up" my amp...
Old Aug 15, 2014 | 10:47 AM
mkguitar's Avatar
mkguitar
On many models the white wire is used for high beam- from the hi/lo switch, white carries power to the high beam filament. it also splits off to the high beam indicator on the dash.
that wire will only have power when the hi beam is selected.
my 2009 wiring diagrams show no capped or unused white wire ( with no other color striped on it).
while it is tempting to add acc to the unused EU spec "city light" or "position light" wiring, overloading this circuit ( shown below) - depending on model/year may leave the rider without lights...or a completely dead ride if the ign. switch contacts burn up.
the owner should look at the gauge of the wiring and the rated fuse of the entire circuit they are tapping into...the position light wiring is designed for a 5 watt light bulb, so the owner takes responsibility if the mod goes wrong.
...I use mine for my XM radio
orange/white is +
blk is ground
mike
Old Aug 16, 2014 | 05:11 AM
jdlogan's Avatar
jdlogan
The wires were for the HID headlight option. But now I use them to power the GPS.
Old Aug 16, 2014 | 06:53 PM
slapshot12's Avatar
slapshot12
Mine power my XM. They are a standard 1/4" spade connector. Very easy to tap into.
Old Aug 17, 2014 | 01:47 PM
cyclgoat's Avatar
cyclgoat
Default Not for headlight!
I work on Harley's and the two wires by the headlight plug are for acc. You can't put any high voltage stuff on those. To hook up a gps, like I did, you have to get a gps hardwire kit. It has a box inline that regulates the power to your gps so you don't blow fuses. If you have an acc switch on the dash, the plug for that is under the seat by the battery.
Old Aug 17, 2014 | 03:36 PM
Roger That's Avatar
Roger That
It's to power the "Space Modulator", lol.
ridedaddy
Audio Systems
Mar 17, 2014 02:39 PM
alandchris
May 8, 2012 05:55 PM
TedMan
Mar 9, 2012 08:56 AM
Udawg
Feb 12, 2012 09:59 PM
petemac
Jun 6, 2008 12:57 PM
