Using Zumo 660 and CB and Bluetooth.
Old Aug 16, 2014 | 01:30 AM
Highwayman-AL's Avatar
Highwayman-AL
Thanks for all the answers and patience. Big help on going forward.
Thanks for the clarification on the Mic and phone. HDBoom will be on my list for next month.
Old Aug 16, 2014 | 01:34 AM
Highwayman-AL
Originally Posted by Stang951
Negative. To be able to speak through your mic and it register to the zumo you will need an HDBOMM. On the Y harness from the Zumo motorcycle mount, there are the output which goes to the aux on the front of your radio, and a 2.5mm plug where the mic plugs into. The HDBOMM uses the mic signal from your bike communications system and sends the signal to this plug.
The AUX switch he was talking about above is the port you have the GPS plugged into now. Stay with me this can get confusing...there is also an HD module for the Road Tech Zumos that you can purchase. It will send the GPS verbal directions to all functions of the radio. Right now you can only hear the directions in AUX mode on the radio. If you had the HD module you can hear the directions when using CD, Radio (am or fm) and Weatherband. Check out the NAV module here.
Thanks HDBomm is on my list then for next month.
AUX switch is for accessories attached to the plugs under the seat. The SPOT switch is for the spot lamps.
Ok, then it should be lighting even though I don't have anything connected to it. So when I get heated gear that will be used to turn on the gear.
Originally Posted by Weavr99FLHT
ACC switch, not AUX.
Yes, Wrong verbiage again, ACC, not AUX, that would make sense, duh.
Old Aug 16, 2014 | 08:52 AM
Stang951's Avatar
Stang951
Mine does. And yes heated accessories are a good example.
Old Aug 16, 2014 | 12:55 PM
cficole's Avatar
cficole
That's what I get for looking at the manual instead of the bike. It calls that switch "Auxiliary (SPOT)".
Linville Lion
Mar 1, 2011 09:51 AM
soft 02
Feb 5, 2011 11:53 AM
rearnold
Aug 28, 2009 10:18 PM
JMJOHN
Aug 15, 2009 11:25 AM
Captain Itch
Aug 26, 2008 07:42 AM
