Need to replace battery / need help on removing caddy
Old Aug 18, 2014 | 05:05 PM
UltraClassicElectraGlide's Avatar
Default Need to replace battery / need help on removing caddy
Bought a new battery and had recently replaced the battery on a 2001 Electra Glide Classic, which took maybe 3 minutes to access and remove. 2010 model? Well, ease of access has changed.
I've removed everything that needs to be removed and am having a problem with the caddy not wanting to come out for the final step to access the battery. I can't see why it moves around but won't pull out from the gas tank side (top of photo).
Can someone tell me what I'm doing wrong?
Thank you.
EDIT: Okay, I got it off. Turns out there was a dealer-installed electrical cable for the battery tender that the caddie was hitting as I pushed it forward towards the tank. It was just enough that the caddie couldn't move forward enough to then clear the metal tab.
Attached Thumbnails Need to replace battery / need help on removing caddy-2010-flhtcu-battery-access.jpg
snerp
Sep 11, 2017 01:43 PM
petrocastle
Mar 21, 2011 10:28 AM
ggf
Mar 3, 2010 05:06 PM
crasha51pan
Nov 29, 2009 04:52 PM
ChileMike
Aug 30, 2008 12:49 PM
