Pinging with PCV
Old Aug 24, 2014 | 07:48 PM
fourburgs's Avatar
fourburgs
Default Pinging with PCV
2009 Rk with stock head pipe , Big sucker A/c Bassini slip ons.. Pinging on full throtlle . Thinking its a timming issue . At what point should I remove timing . My map is adding 4 from 2250 up @ 100 % throttle column .
Old Aug 24, 2014 | 08:42 PM
ke5rbd's Avatar
ke5rbd
Here is one I did up yesterday, not sure it will work, but not hard to find out. This timing map is running on several PCV maps I have put on. It also probably has more fuel than needed there which will also help with ping. The hotter the engine gets the leaner it gets, the leaner it gets the hotter it gets. If it still pings knock all the timing off in the 100% column. You have to unzip before using it. If trouble send me a PM with your email and I will send it to you unzipped. Make sure you tell me what you want as I won't recognize your email name.
File Type: zip
08-09 Touring Stage 1 .zip (975 Bytes, 45 views)
Old Aug 26, 2014 | 02:46 AM
Watch Guy's Avatar
Watch Guy
Default Get rid of all the timing
and zero out all the columns for the ignition timing. You'll find that will eliminate the pinging.
Old Aug 28, 2014 | 06:15 PM
fourburgs's Avatar
fourburgs
Great map .. Thank you.. Added fuel in Zero throttle for popping but other than than pulls hard and runs great Thanks
Old Aug 28, 2014 | 08:06 PM
ke5rbd's Avatar
ke5rbd
Thanks for the feedback. Glad to help.
bozo
Jun 8, 2012 10:25 PM
Craftynicknamehere
Sep 21, 2011 02:50 AM
JollyRogers
Jul 19, 2011 07:33 AM
Watch Guy
15
Sep 3, 2010 03:34 AM
JustDennis
Mar 8, 2009 01:58 PM
