Supplementary 12 volt Power Source
Old Apr 8, 2007 | 01:33 PM
dankral's Avatar
dankral
2nd Gear
Default Supplementary 12 volt Power Source
Has anyone had success adding the Supplementary 12 Volt Power Source (Kit Number 91843-97) to a Road King FLHRI? When I received the kit it says it will fit "1994 and later carbureted FLHR models", but no specific mention of the FLHRI. The harness connector plugged in perfectly to the accessory plug under the seat, but I received no power? I tried both my GPS and a radar detector as well just to verify. Neither device received any juice. I'm assuming now that the configuration of the accessory plug under the seat must be different between the FLHR and FLHRI models even though it fits the same?
If anyone has any info or recommendations I'd greatly appreciate it. Trying to get a power source for my GPS (12V cigarrette lighter style plug) without making any major modifications. This kit seemed the right way to go.
Thanks in advance.
Dan
Heidelberg, Germany
[IMG]local://upfiles/29032/E901039C81E24C208CBECC21DE91DCAF.jpg[/IMG]
Old Apr 8, 2007 | 02:02 PM
Ionvex's Avatar
Ionvex
Default RE: Supplementary 12 volt Power Source
just a couple of thoughts.
Is it plugged in to the switched accessory plug?
Did you flip the accessory switch opposite of your passing lamp switch?
Old Apr 8, 2007 | 03:31 PM
HD Renegade's Avatar
HD Renegade
Could be you have power for the outlet from the powered wire, but you may not have a ground needed to complete the circut??
Bob
Old Apr 9, 2007 | 09:31 AM
jbhawley's Avatar
jbhawley
on the female plug under the seat, one set of connectors are all the time hot (wired to the battery) the other set is hot only with the ACC switch on. Make sure you have the ACC switch on or either reverse the connector pins.
May 5, 2018 08:17 PM
utazzit
Apr 30, 2017 10:15 AM
Boom
Jun 4, 2010 06:27 PM
bruce86023
Feb 4, 2009 02:51 PM
BruceHarrisJr
EVO
Jan 26, 2008 08:36 PM
