LRS Vented Fairing
Old Sep 5, 2014 | 10:10 PM
GPHDXLC's Avatar
GPHDXLC
I have a 14 King and I would consider one if it would fit the existing windshield mounts.
I would not want a radio, just the mounting brackets.
Please up-date when you can.
Old Sep 5, 2014 | 10:19 PM
Mr.Union's Avatar
Mr.Union
Love the lines. Hopefully you'll have a nice system to go with it. Then I can get the whole package from you. If not, I would still take that fairing... Will it fit a 99 rk classic?
Old Sep 6, 2014 | 04:59 AM
RayK's Avatar
RayK
I'd like to see a windshield with a small vent in it to balance out the negative pressure behind it. This would work on all the bikes.
Old Sep 6, 2014 | 05:50 AM
Jrsess's Avatar
Jrsess
Good so far. I would like to see the finished product on a Street Glide! JR
Old Sep 6, 2014 | 06:49 AM
RKZen's Avatar
RKZen
Originally Posted by longrideshields-1
Yes, our plan is to have a multiple side door for the vent.This way, you can open it all the way, 3/4 of the way, 1/2 way or 1/4 way. And, we'll make it so it slides left to right or right to left and it will click into place with each setting. Should be a simple, but effective design. The vent will definitely help eliminate any negative pressure which helps to cause buffeting issues.
This sounds great. Again, if you need a tester, I'm in.
Originally Posted by baldguy13
I'd like to see the outside vent the same color as the fairing.
There are many here who like this idea. Possibly an optional feature?
Will a 'plain-jane' inner fairing be available? Possibly a smooth inner with no cutouts for accessories?
Old Sep 6, 2014 | 06:57 AM
shakrr's Avatar
shakrr
Not for me I am sure a lot like the less buffeting from the 14 mail slot, when I pass one its the first thing I notice. On yours the first thing I notice is all the gaps and edges around the holes and ridges in the shell, which would take a hose to flush out the bugs that I get plastered with. The shell is the easiest part to clean even peppered with bug guts because it is a smooth surface. I and others don't use water to clean just other products. If the black holes were all molded into the ridges of the shell it would be a different story and look better IMO. Also the nice thing about the aftermarket fairing is all the room to install bigger amps and more. It looks like yours going to take away some of that room. I have several of your shields. you asked for opinions, just my thoughts not hating
Old Sep 6, 2014 | 09:44 AM
CBud's Avatar
CBud
I like the way it looks, so far. I have an '02 RKC. What do you think the price point is going to be for a full fairing--inner and outer?
Old Sep 6, 2014 | 09:55 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Nice looking product.
Old Sep 6, 2014 | 10:29 AM
nevada72's Avatar
nevada72
I could be wrong, but it looks to me that you're going for the hot rod shaker hood scoop or blower scoop look. Personally I don't think it translates. To me it's too busy and looks cheap. But I'm in the minority.
As a 14 SGS owner I will say I like the vent and for me the difference is very noticeable. Vent open - smooth air. Vent closed - added turbulence. That's with 3 different windshields. So it's a great idea to build a fairing that has some sort of air flow management. But personally, I think from a clean sheet of paper you can do better than aping the existing Moco product and adding holes and vanes.
Please take that as constructive criticism. I applaud your efforts and like your products. I just think you can do better than this particular design.
Old Sep 6, 2014 | 12:06 PM
Rickpay1's Avatar
Rickpay1
Have a14 cvo road king and looking at fairings now..gonna wait till yours comes out again if you need a tester I am in lol
