Throttle slop
Old Apr 9, 2007 | 04:48 PM
sparky_mo's Avatar
sparky_mo
Default Throttle slop
Is a half inch play in the throttle too much? Just had different handlebars installed and it seems a bit sloppy. Never noticed it before but maybe it was there and I'm just now noticing it because of the new bars.
Old Apr 9, 2007 | 04:50 PM
sleepneagle's Avatar
sleepneagle
Default RE: Throttle slop
No slop, cables need adjusting.
Old Apr 9, 2007 | 05:40 PM
sparky_mo's Avatar
sparky_mo
Did a search and found that some are saying that FI bike with electronic cruise control will have more throttle play. Some say it should not. I guess I am confused as to what to do.
Old Apr 9, 2007 | 06:53 PM
HDChloe's Avatar
HDChloe
Just adjust your cables. Mine had a lot of free play when I brought it home from the dealer. I adjusted the cables and now I have no problem. It will take 2 minutes!
Old Apr 9, 2007 | 07:12 PM
Kahuna's Avatar
Kahuna
Sparky,
Even with a cruise control, there should be only a little play in the grip, but not half and inch! You can adjust this yourself if you choose to.
ORIGINAL: sparky_mo
Old Apr 9, 2007 | 07:15 PM
Phins74's Avatar
Phins74
OK HOW?
Old Apr 9, 2007 | 07:40 PM
Kahuna's Avatar
Kahuna
Identify the throttle cable from the retun cable. Pull back the rubber sleeve from the throttle cable under your RH grip. One cable is for the throttle the other one is for the throttle return. You'll only need to adjust the throttle cable. Using two wrenches, loosen the nut that locks the cable adjuster. Then, start turning the adjuster a few turns. Then move the grip around to check the amount of play. If the play lessen, then do a few more turns to the desired amount of play. Tighten the lock nut back with the two wrenches, slip the rubber sleeve back over the adjuster. You're done!
ORIGINAL: Phins74
OK HOW?
Old Apr 9, 2007 | 08:29 PM
swomack's Avatar
swomack
Mine feels spongy in the closed position, not what I am used to. I adjusted the cables the old fashioned way and found it to be better, then got the service manual and found that on cruise equipped bikes in addition to two wrenches I needed to use a multimeter, two banana peels, a curling iron, and a twelve pack just to adjust the d@mn cable. You also have to remove the left side cover! I adjusted it exactly like the manual says and now it feels spongy again,but by golly its adjusted right.
Old Apr 9, 2007 | 08:43 PM
voodoodrug's Avatar
voodoodrug
What the heal is up with the sm for adj cruise control! I just did its like "normal" previously mentioned after cc was installed and its purfect. Maybe got luck or something to do with that roll off switch being in line with a section of the return cable?
Old Apr 9, 2007 | 09:00 PM
electaRICK's Avatar
electaRICK
ever notice the amount of bald/shaved heads lately???
us poor sob's scratchin our heads everytime we wanna spend 5 mins workin on our new bike!!
