Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
No air in shocks
Old May 24, 2017 | 01:53 PM
pflatout's Avatar
pflatout
Default No air in shocks
Phoned dealer today about ride seemed very hard,they said to let some air out,but there was no air in them,will it do any harm to ride to the dealer,thanks
Old May 24, 2017 | 02:17 PM
Casper's Avatar
Casper
Don't think it'll do any harm, do not use an air compressor or service station air hose, to much pressure. Get a hand air pump, HD or Progressive .
Old May 24, 2017 | 02:20 PM
Cool Inferno's Avatar
Cool Inferno
Check the valve stem core and see if its loose then see if it holds air. Mine was loosing air right after I bought it new. Checked the valve and sure enough it was loose. Add some air and check the pressure on the rear tires. Don't put the recommended tire pressure that Harley uses. Go a couple of pounds under and test the ride.
Old May 24, 2017 | 04:01 PM
ord sgt's Avatar
ord sgt
My FreeWheeler had zero air in the system when I bought it from the dealer. I rode it for a while before buying the H-D hand pump. Could not use any other method to pump up the shocks.
Old May 24, 2017 | 04:15 PM
voiceonly's Avatar
voiceonly
Default No Air... again
This will be the 3rd time I've had to have the air shocks fixed... both other issues I've had hose/line issues. THis is getting ridiculous.
Old May 25, 2017 | 09:12 AM
pflatout's Avatar
pflatout
Had a look today and there is no air line going to the valve and i an not see it.
Old May 25, 2017 | 02:30 PM
Cool Inferno
That's not a good sign. Take it in for sure.
Old May 29, 2017 | 10:28 AM
Lilman's Avatar
Lilman
Do what many have done: 1. Order real shocks from DK or Progressive. 2. Remove crappy factory shocks and throw in trash, use for boat anchor, target practice, etc.
3. Install good shocks, adjust and enjoy!
Old Apr 25, 2018 | 01:05 PM
Wooken's Avatar
Wooken
Stage IV
I just discovered the exact same issue. What did you wind up doing?
Old Apr 25, 2018 | 02:40 PM
Coastal CVO's Avatar
Coastal CVO
See
DK Customs for a better ride and no more leaking air shocks.
firefighter156
2014-2024 Touring Models
Dec 30, 2017 08:12 PM
ord sgt
Feb 19, 2017 03:20 PM
rufasim
Jun 18, 2012 09:07 AM
28gauge
Sep 8, 2009 03:16 PM
agent58
Apr 30, 2008 01:53 PM
