So I sitting in front of my Trike after uncovering it... The flashers just start flashing No tender hooked up to it, Fob was in the windshield bag where I usually keep it since I bought the Trike.
Looked thru the handbook to see if there was a trouble shooting item on this nothing
Changed the battery in the fob...
Short of disconnecting the battery, is there a answer out there in cyber land???
If you had somehow moved the bike by bumping it and the bikes computer was not receiving a signal from the fob, the flashers will light up and prevent a startup, unless you over ride the security system.
Since you replaced the battery in the fob, the security system can now read the signal from the fob. Good job trouble shooting your machine.
