Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Cat Urine/Spray in Wheel
Old Sep 18, 2019 | 05:19 PM
Sur2baja's Avatar
Sur2baja
4th Gear
Default Cat Urine/Spray in Wheel
I did a search but couldn’t find an answer. I’ve had a cat spray my 2019 rear Tri glide wheel and now it appears etched.
  1. Is the wheel coated at all?
  2. Does anyone know how to remove the etching or stain?
Thanks in advance!
Old Sep 18, 2019 | 08:35 PM
Bass Player's Avatar
Bass Player
Let's see a picture of the wheel if you can post one. Wash it well then I'd try Never Dull if they are chrome or Mothers Chrome Polish. Then the cat is another issue.
Old Sep 18, 2019 | 08:43 PM
VAFish's Avatar
VAFish
I know how to remove cats
Old Sep 19, 2019 | 03:10 AM
sloufoot's Avatar
sloufoot
You can also use "Bartenders Friend" liquid to initially clean and buff it out . Then I use "Flitz Polish Cream" to finish the polish. If you can find a good ceramic finish to put on it will keep all the brake dust easy to wash off also.
Old Sep 19, 2019 | 06:05 AM
BelchFire's Avatar
BelchFire
Custom cat hide seat cover ...
Old Sep 19, 2019 | 06:50 AM
santajim's Avatar
santajim
Wenol metal polish and some elbow grease should take it out.
Old Sep 19, 2019 | 08:24 AM
hvacgaspiping's Avatar
hvacgaspiping
A 12 gauge will take care of that cat.......
Old Sep 22, 2019 | 11:37 AM
medicmike's Avatar
medicmike
Don't go getting yourself in trouble for "discharging a firearm in the city limits"! Feed the cat! Tuna is loved by most cats, and be careful that no antifreeze from a leaky overflow canister leaks in the tuna.
Sounds like some of the polishing ideas are good.
Old Sep 22, 2019 | 06:25 PM
jackddg22's Avatar
jackddg22
Put the cat into the microwave.
Old Sep 25, 2019 | 08:32 PM
VAFish's Avatar
VAFish
Neighbors cats make good hats.
https://www.telegraph.co.uk/news/new...into-hats.html
outkast76
Jan 29, 2016 02:47 PM
GLIDEGASM
Wheels/Tires
Apr 8, 2014 12:57 PM
low_wgn
Aug 10, 2009 05:34 PM
metal_mike
Sep 10, 2007 08:48 PM
sbbrown
Mar 9, 2007 03:14 PM
