Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Pipes burning my leg
Old Aug 1, 2013 | 11:55 PM
  #41
UTES's Avatar
UTES
Originally Posted by FrankBarba
Now i'm looking at adding a turbo to bring the heat down.
You mean a parade-type fan? Turbos add power - but additional heat comes with that power.
Bill
Old Aug 2, 2013 | 12:57 AM
  #42
msocko3's Avatar
msocko3
I have a 2013 Tri, the heat is unbearable. At 400 miles i could no longer ride due to the heat issue. I called my dealer they suggested a State 1, with V & H duals, High Flow Air Intake, and HD EFI tune cost 2K. All this did was open up the exhaust, fuel mileage is bad (150 Miles) on full tank, and my leg is getting singed again. Spoke with the dealer again and cost $ 50.00 for them to say that they have the correct program.
I now have 600 miles and the dealer says that is the way it is. Don't know if this is HD's way of blowing off my problem ?
Its your dealers way of blowing you off, HD won't help you with the heat. Depending on the tuner your dealer used you can't even go to HD for help, they'll just flag your powertrain warranty. By the sounds of it your dealer doesn't have a clue on how to tune, I'd find someone else.
Old Aug 4, 2013 | 12:57 AM
  #43
screwball's Avatar
screwball
Two things to try, 1. move your leg. floorboard extensions are about 70 bucks. 2. Remove your lowers. You can replace the crash bar for cheapo with ones from a Street Glide or aftermarket mustache bars. If you have done all the things 'others' have done and it didn't help, maybe you are keeping your legs too close to the engine. Have you been riding Harleys for a long time???
Good Luck.
mcouture
2014-2024 Touring Models
32
Jul 18, 2015 09:19 AM
tbonetony06
Aug 26, 2013 06:52 PM
composed
Sep 9, 2012 04:02 PM
06BlackFLHXI
Jun 8, 2007 10:05 AM
FLSTNI_Man_of_Steel
Apr 21, 2006 06:24 PM
