Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide Rear Shock Inflation
Old Oct 19, 2014 | 10:21 AM
  #31
DiselDevilDog's Avatar
DiselDevilDog
Default Shock Pressure
Hi Oogie,
The shocks are very sensitive and require very low pressure to pump them up. Also, when you are on a trip away from your compressor, you may have a slight leak where the plastic hose goes into the shrader valve. To fix this, pull out the end of the plastic hose after compressing the knurled ring and use a razor blade and cut off 1/8" carefully. Then reinsert the hose. This should make the end nice and sharp and the shrader fitting inside will be able to grab onto the new round hose.
The compressor will fill the shocks too rapidly and you may blow out the seal....invest in a Harley Pump and you can carry it with you while traveling.
You will appreciate having a pump with you all the time.
Diesel
Old Oct 19, 2014 | 01:49 PM
  #32
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by DiselDevilDog
Hi Oogie,
Diesel
+1
I purchased one 9 years ago when I got my first bagger. Still using the same one today...works as well as the day I got it.
Also, remember, as little as 2lbs PSI can make a significant difference in the ride quality.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Oct 19, 2014 | 10:02 PM
  #33
sloufoot's Avatar
sloufoot
Also if you find a leak at any of the fittings that you decide to cut the end be sure to cut it very straight across & use a razor blade so you won't leave something on the edge to damage the seal on the inside of the fitting.
Old Oct 19, 2014 | 11:54 PM
  #34
CaCruizin's Avatar
CaCruizin
There are cheaper alternatives to the expensive HD pump that work just as well....
Old Oct 20, 2014 | 02:53 AM
  #35
sloufoot's Avatar
sloufoot
The nice thing about the Harley Davidson, or Progressive shock pumps is they have a check valve to prevent any backflow, And also a special fitting to release the Schroeder valve before it starts releasing air from the shocks when you take it off.
There are used & new pumps for sale on Amazon & EBay for some less than Harley retail.
Suredyke Harley Davidson have a discount program also.As do other dealers. Check around, the correct pump is worth buying.
The other pumps might work, but I don't think you would be pleased.
But that's just my opinion.............
Old Oct 21, 2014 | 01:13 PM
  #36
CaCruizin's Avatar
CaCruizin
I bought the Progressive Suspension GP3-60 Mini Gauge Pump and it works perfectly with the $10 exension and cost just over $40 which is 2/3rds of the one HD wanted to charge me.
Old Oct 21, 2014 | 03:59 PM
  #37
TrapshooterBob's Avatar
TrapshooterBob
Really? My HD pump cost me $50. 54630-03A Works great.
Old Oct 22, 2014 | 09:01 AM
  #38
RAP's Avatar
RAP
Edited
Old Oct 22, 2014 | 01:08 PM
  #39
CaCruizin's Avatar
CaCruizin
Maybe I was a few $ out, but after CA tax it is a lot more than $50
Old Oct 23, 2014 | 05:01 AM
  #40
bronxbill's Avatar
bronxbill
Harley pump is $49.95 in catalog. I got mine from Surdyke and saved 20% plus no tax
Alohacmc
Air Suspensions
Sep 24, 2017 02:36 PM
Tangle Eye
32
Jun 9, 2013 07:10 PM
TRI GLIDER
14
Oct 15, 2012 06:28 PM
rvdmadcat
Mar 16, 2009 08:55 PM
oilhog
Apr 7, 2008 09:18 PM
