Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Need help no reverse
Old Apr 1, 2011 | 06:46 PM
T K Glider's Avatar
T K Glider
Default Need help no reverse
Sounds like it's turning but no reverse.Is there a reset somewhere or must it go back to the dealer?
thanks in advance,,
T K
Old Apr 1, 2011 | 07:45 PM
tbob's Avatar
tbob
Red reset button under right panel.
Old Apr 1, 2011 | 07:52 PM
carlo's Avatar
carlo
Or under the seat on a 09. Right panel on a 10 and 11
Old Apr 1, 2011 | 08:44 PM
T K Glider's Avatar
T K Glider
Hit that red button many times.Does not reset rev.IS THERE AFUSE ALSO?
Old Apr 1, 2011 | 09:49 PM
tbob's Avatar
tbob
Yes there is a fuse. That may be the problem.
Old Apr 1, 2011 | 10:31 PM
T K Glider's Avatar
T K Glider
Fuse in left side fuse panel?
Old Apr 2, 2011 | 03:40 AM
tbob's Avatar
tbob
The manual states with this sound 1 Ring gear test 2 Reverse Motor Solenoid test or
reverse motor malfunction. Hope this helps.
Old Apr 2, 2011 | 07:27 AM
T K Glider's Avatar
T K Glider
Can not figure that post.
Old Apr 2, 2011 | 08:17 AM
T K Glider's Avatar
T K Glider
Thanks everyone it is up and running.I did not see the black lever beside the red button.That is the reset.Closed the lever and reverse is back on.
thanks again,
T K
Old Apr 2, 2011 | 10:16 AM
Casper's Avatar
Casper
Glad it's back to working for ya
