Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
flip
Old Aug 13, 2011 | 09:56 AM
jim gallo's Avatar
jim gallo
Default flip
has anyone ever heard of a triglide flipping over in a turn? i was is western maine yesterday on some really twisty mountain roads and took a curve alot faster that i realized and it felt like one rear wheel lifted. first time i ever had that feeling and was just wondering if its ever happened.
Old Aug 13, 2011 | 11:14 AM
oldmsocko's Avatar
oldmsocko
I have never heard of one flipping but anything can happen if a person totally over drives a curve.
Old Aug 13, 2011 | 01:03 PM
bronxbill's Avatar
bronxbill
Haven't heard of one flipping, but I have experienced what you are talking about when I took a curve on the Blue Ridge waaaaay too fast. Scary, but I think I was a ways from flipping.
Old Aug 13, 2011 | 01:23 PM
j1mmy's Avatar
j1mmy
im sure the suspension is pretty good these days,but 20 years ago,trikes were known to be dangerous and tipped all the time..just like the atcs that were outlawed..one front wheel makes it unstable to start and its top heavy..the bike was made to lean,the rear wheels are fighting it on every turn
Old Aug 13, 2011 | 03:30 PM
screwball's Avatar
screwball
Can't remember if it was this forum or TrikeTalk, a guy said he went into a turn too fast and the bike wouldn't turn, ran into a wall. Wife is a VERY aggressive trike rider and hasn't had any problems, mine has never felt like it was tipping. I rode Quads and 3 wheel ATC's for years, the Harley Trike doesn't feel that much different.
Old Aug 13, 2011 | 04:49 PM
Keystone's Avatar
Keystone
Front end normally starts to hop before the rear lifts. But if you are on a road that is bumpy in the curve and is crowned against the turn that would help lift the rear a bit.
I can tell you for sure they day I was going sideways down the Interstate she did in fact try to roll over. Took allot of steering to get it under control. But that was due to the accident, not going into a corner too hot.
Old Aug 13, 2011 | 11:52 PM
dw2169's Avatar
dw2169
I always thought the front wheel would slide before the rear would lift, I found out I was wrong, I hit a corner following a Goldwing who was scraping floorboards big time and lifted the rear wheel off the ground about 6 inches, sure did pucker my behind.
Old Aug 14, 2011 | 03:08 AM
msocko3's Avatar
msocko3
Where you running the rear lift brackets at the time?
Old Aug 14, 2011 | 04:35 AM
jim gallo's Avatar
jim gallo
no my 2011 is totally stock. i was ridding 2 up, i did not feel the front wheel slide. it just felt like one rear wheel lifted.
Old Aug 14, 2011 | 10:10 PM
dw2169's Avatar
dw2169
Yes I was but I think speed had a lot to do with it lifting, this was a u shaped corner with a 20 mph speed limit, we were two up, loaded with luggage, probably doing 60 going into the corner, the wheel lifted, no front wheel hop, I turned into to it just enough to bring the wheel down and back to turning the corner and then into another corner. Really no time to think about it. I know before I could ride with this guy on the Goldwing and just seem to be coasting around the corners when following him with my old trike. My old Lehman trike the back was just as high as the 11 trike with the lift kick so that really should make any difference.
