Twin Cam Motors Twin Cam 1998 thru 2017
Performance Plug Wires
Old Jun 19, 2022 | 11:39 AM
60Gunner's Avatar
60Gunner
Default Performance Plug Wires
Anyone running these plug wires from Speeds Performance Plus?
Speeds Performance Plus Plug Wires Part # SPC1HC40
I'm a fan of the Taylor/Sumax 8mm Pro for their added insulation and positive lock. 350 ohms per foot but still work with Harley's ion sense. But the ones from SPP got my attention and are 40 ohms per foot yet still provide high EMI/RFI suppression.(note:not just RFI)
The high spark energy is supposedly good for 2-8hp repeatedly in their dyno testing over the stock wires. I can understand how the better spark can add performance. I remember Hillside saying they consistently get another couple HP gapping the NGKs @ .035 for a stronger spark.
My question(s) is are they as good as they claim and give any kind of performance boost and do they work with the ion sense or do you disable it? I'm not opposed to disabling it if they're a worthwhile upgrade. I've got a real good tune and it addresses any possible pinging issues due to heat without retarding the main spark tables and affecting the tune any longer than necessary for the condition to correct itself.
Also, I'm currently running the DCPR8E with my 212psi CCP and wondering if anyone is running the DCPR9E with their high compression build. If so, what's your cranking compression?
Not interested in the typical "stock is best" responses. Not without proof to back it up in the form of repeated dyno runs under identical conditions anyway. That should eliminate most of those responses. I can promise you the stock 6R12 plugs are NOT the best for a high compression build. Too hot a plug.
If you're running an HD plug 1 or 2 steps colder on the other hand, I AM interested. (Is there such a plug? Vrod plug maybe?)
Mostly just interested in plug heat range comparisons in builds with a CCP of 20 or more.
Thanks for any and all HELPFUL responses/experiences good or bad.
Old Jun 20, 2022 | 07:00 AM
buell95's Avatar
buell95
Haven’t ran these wires but they look just like the Twisted wires I run on my 124.
Old Jun 20, 2022 | 12:28 PM
djl's Avatar
djl
Running 9es in my 98" motor; CCP is 213psi.
Old Jun 21, 2022 | 07:56 AM
eighteight's Avatar
eighteight
I`d be interested in the same "proof" being supplied by Sumax
Old Jun 21, 2022 | 08:59 AM
67Shuv's Avatar
67Shuv
I went with the 10mm SE wires a year or so ago. Seemed to have cleaned up some ground noise issues I was having and if it’s not just in my mind it tends to idle better.
Old Jun 21, 2022 | 01:13 PM
Flo-rida's Avatar
Flo-rida
Well gunner. Did you buy them?
was looking at plug wires myself
Old Jun 22, 2022 | 07:19 AM
PureHybrid's Avatar
PureHybrid
Taylor makes a 10mm wire, I've seen them listed on Summit before. Not sure on specs vs the 8mm as I can't find anything in the motorcycle section on their website besides 8mm
Old Jun 25, 2022 | 02:08 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Are you supposed to use Carbon core wire sets? Like with the Evo's?
Old Jun 25, 2022 | 03:12 PM
Tired's Avatar
Tired
Deleted
SavageChopper
Aug 23, 2016 04:21 PM
PaulsStreetGlide
Nov 26, 2013 11:26 AM
ib5150
May 29, 2013 11:40 AM
tazz32
Mar 4, 2010 09:51 AM
trusty1
May 23, 2007 10:53 AM
