VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Slight misfire.
Old Sep 21, 2018 | 09:52 AM
Kingglide549's Avatar
Kingglide549
Originally Posted by TimCorrey
Define some things for me, please:
AFR
SERT
SERPT
I dont know about the others but AFR is pretty common as air-fuel- ratio.
Strychometeric is purrfect but not wanted in the Harley world.
With the AFR meter, you will be able to see what is going on NOW
.It is the best tool you will have ever bought and the best option you ever put on your bike.
I dont know why the new computerized BS does include away to monitor it, as they already have an O2 sensor in there,
Old Sep 21, 2018 | 11:55 AM
TimCorrey's Avatar
TimCorrey
6th Gear
Thanks. I will look them up.
Which one do you have in stalled?
Old Sep 21, 2018 | 12:47 PM
bbmach's Avatar
bbmach
Glad you are making progress!
My '04 has a K&N air filter, Vance and Hines Powershots along with a DynoJet Power Commander. I was able to "borrow" a custom map from someone on the V-Rod forum (now 1130) back when I did it in 2004 - as they had a custom map made from dyno-tuning with the same set up... and it runs delightful. As you're finding out, once you move past stock with the intake and/or exhaust, you'll need to compensate for the narrow fuel map from H-D. This applies to pretty much all Fuel Injected H-D bikes, but as Kingglide549 said, it is easier with the 02 sensor already in the head pipe. Earlier bikes don't have that to work with... hence the need for individual dyno-tune maps.
Old Sep 21, 2018 | 06:50 PM
houstonhdguy's Avatar
houstonhdguy
I’m guessing your TAB tuner is the problem. I’ve had a tuner go bad before and the bike would stutter on acceleration.
Old Sep 22, 2018 | 02:43 AM
BBM's Avatar
BBM
SERT
SERPT
Screaming Eagle Racing Tuner
Screaming Eagle Racing (Pro?) Tuner - (newer version)
Both allow access to bikes original fuel management to make changes on a dyno. Best option IMO.
Old Sep 24, 2018 | 05:29 AM
Kingglide549
AME from amazon
Amazon Amazon
Old Sep 25, 2018 | 05:22 AM
TimCorrey's Avatar
TimCorrey
6th Gear
Does the AME Air Fuel ratio meter setup use the existing O2 sensors?
Old Sep 25, 2018 | 05:52 AM
Kingglide549
The kit includes a wide band with bung .
I have no clue if the factoryO2 could be sistered off of
My gut tells me HD just uses a cheap O2 sensor that will not do the job.
Old Sep 25, 2018 | 05:58 AM
TimCorrey's Avatar
TimCorrey
6th Gear
Okay, I can install in my shop.
So we are sensing the combined exhaust stream.
I wondered because the OEMs monitor each cylinder.
AEM looks good.
Old Sep 25, 2018 | 06:04 AM
Kingglide549
You can go as elaborate as you like- there are dual monitors for sale.
Usually, if you use the single it should be installed in front cylinder.
Wizardofaus
Jun 14, 2017 02:29 AM
kehow
VRSC Models
Jun 7, 2017 04:35 PM
flyboyron
2014-2024 Touring Models
Jul 25, 2016 08:57 PM
ptl203
Sep 4, 2015 04:42 PM
Nazkad
Jun 3, 2013 11:57 AM
