VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Slight misfire.
Old Aug 25, 2018 | 01:49 PM
TimCorrey's Avatar
TimCorrey
6th Gear
Default Slight misfire.
2009 VRSCAW 1250
Recently started a hesitation or slight misfire except when accelerating.
Any suggestions?
Old Aug 25, 2018 | 01:53 PM
OzHD's Avatar
OzHD
Keep accelerating?
Old Aug 25, 2018 | 01:54 PM
Iceman24's Avatar
Iceman24
Well...this is a "crap-shoot" without knowing some things about your bike.
Any mods (e.g. tuner, exhaust, bars, intake, cams)?
Any recent work?
New/old gas?
Bike gets ridden, or was it in storage?
Old Aug 26, 2018 | 07:38 AM
TimCorrey's Avatar
TimCorrey
6th Gear
Thanks for the Reply Iceman24.
Fresh Gas.
Gets ridden frequently.
Recent work: New rear tire.
Currently running TAB tuner that came with TAB shorty slips ons. Didn't like Tab exhaust, removed after short time.
I like the stock exhaust, so modified for sound.
Removed baffles from stock exhaust last year. Bike has run well in this setup for a year.
Running tuner on bypass - Harley ECM is controlling fuel injection.
Old Aug 26, 2018 | 07:42 AM
TimCorrey's Avatar
TimCorrey
6th Gear
VRSCAW Slight misfire.
Plan at this point is to have HD tune the ECM so we know the map is good.
Old Aug 26, 2018 | 08:01 AM
Iceman24's Avatar
Iceman24
Funny how she ran good for a year w/the exhaust swap & now starts the misfire. Did you check exhaust for any leaks (fm flange to exit)? All is tight/torq'd...??
Agree w/the dealer flash & let us know if it helps...good luck!
Old Aug 26, 2018 | 08:05 AM
TimCorrey's Avatar
TimCorrey
6th Gear
Thanks.
Old Aug 26, 2018 | 03:37 PM
bbmach's Avatar
bbmach
What do the spark plugs look like.
Old Aug 26, 2018 | 06:40 PM
TimCorrey's Avatar
TimCorrey
6th Gear
Thanks for the reply, bbmach.
I pulled the rear plug because it is easy to access. The color is nice and tan, but the gap is .045 due to wear. Should be 0.035.
I am going to replace both the plugs, gapped properly, to eliminate spark plug deterioration as a possible cause.
I will update.
Old Aug 28, 2018 | 02:03 AM
BBM's Avatar
BBM
Not a big fan of TAB and not a big fan of flashes or generic maps. I would start there. If HD is to tune the existing ECM, you need a SERT or SERPT to gain access.
