VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Drilled exhaust
Old Aug 8, 2007 | 06:13 PM
syata's Avatar
syata
Default Drilled exhaust
I finally drill my exhaust on my 2003 V-Rod. I first tapped the start then (as it was suggested) started drilling small holes then larger. I stopped at 1/4 inch. It does sound a lot better, deeper than stock. I drill 8 holes per pipe. I might go larger after a while.
My question, do I have paint the back plate? It does not seem that the area is that large, only the edges that are bare metal.
Thanks for the feedback.
Old Aug 8, 2007 | 08:01 PM
eazy's Avatar
eazy
Default RE: Drilled exhaust
It should get hot enough to not be an issue. The headpipes aren't painted and you don't see them rusting. You are a ways away from the heads so if you do use high-temp paint, otherwise you'll just bake it off.
Old Aug 8, 2007 | 10:22 PM
syata's Avatar
syata
Thanks for your advise. Since I still have the 1/4 holes. I will ride with what I did and decide if I want to drill larger. So I will forgo the painting part for now.
Old Aug 18, 2007 | 03:54 PM
wildpig1ms's Avatar
wildpig1ms
syata, did you do anything to the intake and/or computer or did you just drill these holes?? I got a friend who's wanting a little more sound out of his Vrod but don't want to go thru the intake and remapping just to get it.......
Thanks,
Ken
Old Aug 20, 2007 | 03:13 PM
syata's Avatar
syata
I just did the drilling. You can hear a difference with 1/3 and 1/4 holes adn did not cost me any money.
One advise, tap out the holes first, you can use a tap or even a screw, that way you can start the 'hole' and the drill will not slide across when you try and drill the actual hole.
Old Aug 21, 2007 | 11:08 AM
dogyakker's Avatar
dogyakker
Forgive my stupidity but exactly which parts did you drill? I'm interested in this but havent got a clue what you are all on about!!
Thanks
Chris
Old Aug 21, 2007 | 01:09 PM
syata's Avatar
syata
To get more volume out of your stock pipes you can drill holes into the back plate of your mufflers. People did experiments on the V-Rod in which you don't have the engine remapped if you stay below 1/2 inch with 8 holes per pipe.
I drilled my stock pipes to 3/8 inches and noticed a large difference, It now sounds deeper mpore throatier. You might get a slight in performance increase too, but that probably will be very minor.
There are several how to files if you are interested. It will take you less than 1/2 hour to do so with a power drill and drill bits.
Old Sep 28, 2007 | 08:52 AM
simon.jmb's Avatar
simon.jmb
Stage III
Hi Guys,
I assume that this is the same for a Street Rod?? Let me get this right, 8 holes in each back plate at that size=no remapping or weak running etc? has anyone heard the Street Rod with this done?
Skyman
Old Sep 28, 2007 | 09:26 AM
eazy's Avatar
eazy
The answers to all of your questions is Yes
Old Sep 28, 2007 | 11:12 AM
syata's Avatar
syata
As Eazy says, "yes" but from what I researched on the net, when you do the 8 holes, the max you can go per hole is 1/2 inch. If you go larger then you might have to get the bike re-mapped. I would stay under 1/2 inch per hole. So 8 holes in the upper pipe plate and 8 holes in the lower pipe plate. That is what I did and it sound throatier, but too loud like Thunderheaders.
I tapped the places where I wanted the holes with a Punch for a cleaner look - otherwise the drill might slip and scratch the pipe plate. Don't put too much force when you drill you might go into the outer baffle (I did that). I would stay closer to the center of the pipe plate (I should have done this).
Good luck.
Stephen
