VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Brake rotor
Old Dec 3, 2009 | 08:43 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Default Brake rotor
I have a 08' FLHX Street Glide that has Brembo brakes with the 11.8" brake rotors. I was told the VRods have 11.8" rotors. Anyone here confirm that is true? If so, I would like to buy a used rotor for a project if anyone has one...or if it works, two. What I would like to do is make a semi floating center that will bolt up to the VRods's rotor and my SG's wheel hub. Thanks.
Old Dec 6, 2009 | 09:56 AM
tjvrodrick's Avatar
tjvrodrick
Try asking that at http://www.1130cc.com/forums/index.php
alot more v-rod guys there
Old Dec 8, 2009 | 01:00 PM
Hogpro's Avatar
Hogpro
Former Sponsor
2000-2006 vrods mostly came with 11.5" brake rotors but the 2007 and newer ones came with 11.8".
Old Dec 8, 2009 | 11:55 PM
Hal64hd's Avatar
Hal64hd
Actually there was no v-rod in 2000. 2002-2005 have the 11.5 with the exception of the "r" model in 2005 (which had the 11.8) 2006 and up all have the 11.8, 2008 AW with the spoke front wheel is what you are after. The disc bolt pattern on all previous models wheels are different and don't think will work for you application
Stomper-63
Jul 6, 2020 03:11 PM
pdog75
General Topics/Tech Tips
Oct 7, 2016 10:08 AM
TwoBlue02
Sep 12, 2016 06:20 PM
machm1969
Jan 24, 2014 08:55 AM
soos
Oct 24, 2010 09:33 PM
