VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Alarm disfunction
Old May 4, 2010 | 01:40 PM
Naples Muscle's Avatar
Naples Muscle
Stage II
Default Alarm disfunction
hey folks,
I have a 2009 VSRCF with 1600 miles on it. Tonight, when I tried to start it, the alarm did not disarm and the bike did not start. I pulled the 40 amp fuse and re-seated the alarm module switch and it started right up.
I put the seat back on and tried to re-start it and no-go!
Anyone have any ideas or is there a H-D recall on alarms that I haven't heard about?
Help!
Thank in advance,
JP
Old May 5, 2010 | 06:49 AM
SteelHorseDX08's Avatar
SteelHorseDX08
6th Gear
Is the bike throwing and Sec or other codes?
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
1- Ignition off
2- push odometer reset button in & hold. Make sure run switch is on.
3- turn ignition to run and release button (you will see P, S &C displayed)
4- each letter represents an area of diagnostics... the one that is flashing is the one you are going to check. To move from one letter to the next, you push the button one time. (from P to S to C and back to P, etc.)
5- to get DTC within an area, you push and hold the button in for 5 seconds and if there are any, it will be displayed... you can release the button. As you push the button again, other codes will appear if they are there. If there are not any the word 'none' appears.
6- Record the codes.
7- To determine if a code is current or historic, you clear the codes while being displayed by pushing in and holding the button until 'clear' comes up. Turn off the ignition... then crank or restart the bike... turn off, and then repeat the code process. If a code is there now, its current... if not, it was historic.
Tnks to MAX for posting this info.
frankegd
2014-2024 Touring Models
Jul 25, 2014 10:16 AM
dplantz
May 9, 2014 09:10 PM
69cj
Feb 22, 2011 04:34 PM
Bobber M
Apr 4, 2007 09:05 PM
blukrom
Sep 4, 2005 02:15 PM
