ECM issues
Old May 26, 2020 | 10:52 AM
ilwirider77's Avatar
ilwirider77
Stage III
Default ECM issues
I'm running a FP3 on a Harley 2014 103 and no problems for several years, but now the idle will periodically run high, 2000 RPM or so and then a few miles later it won't idle at all. I'll then need to reconnect the FP3 and reset. The engine will run fine for several hundred miles then the same thing occurs. Didn't want to try a dealer tech yet since so many are kids without much experience. Any ideas on what could be causing the problem? is it the ECM ?
Old May 26, 2020 | 11:50 AM
TracerBullet's Avatar
TracerBullet
Welcome to the forum
Old May 26, 2020 | 11:52 AM
squirrelsnest's Avatar
squirrelsnest
Welcome! to the forums from Virginia...…………..
Old May 26, 2020 | 12:16 PM
Hairy Larry's Avatar
Hairy Larry
Big Kahuna HDF Member
Welcome from Texas
Old May 26, 2020 | 12:32 PM
Fiachra's Avatar
Fiachra
Welcome from Willoughby!
Old May 26, 2020 | 12:42 PM
BuzzCap7's Avatar
BuzzCap7
Hi there i77.This “Welcome Area Only” section is for, well, welcoming only. Like, introducing yourself and what Harley (hopefully Harley) you ride.
Stuff you are talking about up above in your OP (Original Post), needs to go to the proper and more relevant area to get our rider’s input.
In the UPPER LEFT corner, just take your mouse and ROLL OVER “Forums” and come down to the section (or subsection) that you feel is most appropriate. It is that easy.
Thank you my friend for understanding.
It is GREAT to have you here with us.
Warmly & Respectfully,
BuzzCap7
Old May 26, 2020 | 02:07 PM
kel03's Avatar
kel03
Old May 26, 2020 | 03:39 PM
470004's Avatar
470004
Welcome from New York.
Old May 26, 2020 | 03:51 PM
Spartanden's Avatar
Spartanden
Good Luck!!
Old May 26, 2020 | 03:53 PM
Uncle Larry's Avatar
Uncle Larry
Welcome To The HD Forums From Michigan, The Home of Hell, And The Greatest Of The Great Lakes States ... Everyone Here Knows Something And Some Here Know Everything !
