ironhead eletrical
Old May 24, 2008 | 09:19 PM
rickamx's Avatar
rickamx
Stage IV
Default ironhead eletrical
Hey I just joined and I need help. I have a 77 ironhead chooper. there is an eletrical problem I am having a hard time figuing out. In a nut shell the wire from the coil to the points is some how being grounded when it touches the case or is hooked up to the points. If i touch the wire to the primary cover it arcs. I have checked all wiring for exposed areas. found the starter wire had arced on bottom of battery tray, fixed it. batery ground was bolted to frame. wiring diagram shows it should be attached to case, I changed that. If ay onehas any suggestions they will beapricated. Thaks Rick
Old May 24, 2008 | 09:24 PM
danielo's Avatar
danielo
Default RE: ironhead eletrical
Welcome,from Pampa Tx. I'am not a mech.you might want to ask your question in the Tech Forum on the main page.
Old May 24, 2008 | 09:33 PM
rickamx's Avatar
rickamx
Stage IV
Thanks, I will look for main page tec stuff.
Old May 27, 2008 | 10:05 AM
XRP's Avatar
XRP
Welcome from Cold Lake, Alberta.
Danv508
Ironhead
38
Mar 18, 2017 09:30 PM
Mugsy666
Aug 10, 2016 02:38 PM
MAGSRFFR
Electrical/Lighting/Alarm
Jan 13, 2011 05:21 PM
RoadKing52
Mar 13, 2008 09:09 PM
Shovelhead77
Mar 12, 2006 01:54 AM
