Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
I have 02' Ultra, all lights worked fine when I parked it last night.....when I started it the next morning, high beam indicator light was on, I switched it off, indicator light stayed on. I have no headlight, passing lamps or brake light ,but turn signals and tour pak lights work,can anybody help me out......dealer keeps em' week to 10 days after you can get it in.......Thanks
Sounds like you have a short there. The passing lamps and headlight are powered from the same source. I am not sure about the brake. If you check the fuses inside the left electrical cover that might be a start. If you find one blown, then you will have to start looking at stuff.
Is there anything new, any changes etc. on the bike?
Good luck.
