93 Evolution Timing
Old Apr 23, 2011 | 10:46 AM
firsthd's Avatar
firsthd
6th Gear
Default 93 Evolution Timing
Timing of this engine is a #$%#@$ pain.
In an effort to time the ignition of the motor, I remove the spark plugs and use the starter to turn the motor over.
This prevents alot of oil from blowing out the timing hole.(as I cant see anything thru the plastic timing hole tool)
When I check the advance mode I put a vacuum onto the VOES to make contact with ground.
Right now whether I have the vacuum on or not, the ignition timing is on the dot of the flywheel (35 degrees advanced, not the line for TDC)
It apears that my ignition system is locked in the full advance mode.
Is this at all possible that the ignition module is stuck in the full advanced mode?
Old Apr 23, 2011 | 10:47 AM
racerdj's Avatar
racerdj
You might get some tech help in that section.
Old Apr 23, 2011 | 12:33 PM
firsthd's Avatar
firsthd
6th Gear
Thanks for the advice...I'm having difficulty today...it's an old guy thing
Old Apr 23, 2011 | 12:50 PM
Snarly's Avatar
Snarly
Welcome Firsthd. Go to the tec section, get better results than here.
https://www.hdforums.com/forum/gener...ech-forums-58/
See ya in the main forum.
Snarly
Old Apr 23, 2011 | 02:40 PM
Gator454's Avatar
Gator454
Welcome to the forum from southeastern Michigan, U.S.A.
Old Apr 23, 2011 | 03:22 PM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
Old Apr 23, 2011 | 04:17 PM
firsthd's Avatar
firsthd
6th Gear
Thank you all, it's nice to have a p[lace where we can all talk about our scooters....hehe
Thabnks again... I got this post thing workin and put this post on the tech site...
Old Apr 23, 2011 | 04:33 PM
UK FXSTB's Avatar
UK FXSTB
wellcome from England.
Old Apr 23, 2011 | 07:16 PM
JackDupp's Avatar
JackDupp
Welcome to the forum Firsthd, enjoy your stay.
Old Apr 24, 2011 | 07:28 AM
Zap's Avatar
Zap
Howdy, welcome to the forum, hope you enjoy your experience here.
