oil sumping
Old Aug 25, 2012 | 03:52 PM
robk195's Avatar
robk195
Stage I
Default oil sumping
hey folks...just finished my rigid w/ 1340 evo out of an 87 FXR...got it started on thursday,then it was super hard turning over....oil was coming out of the crankcase breather like a m.f....i've tried a brand new starter from spyke,1.4 kw,super torque....i've put the trans in 4th gear,and pulled the back wheel over until it seemed like no more oil was coming out of the crankcase boss...pulled both plugs out,and finally it turned over...but only turns over with the plugs out. the motor ran perfectly when i took it out of the donor FXR...WTF am i missing??? any help would be greatly appreciated!
Old Aug 25, 2012 | 03:56 PM
3408pete's Avatar
3408pete
did you plumb it up right on the oil lines???I have heard of that allowing one to dump a lll the oil out of the bag into the crankcase and if it is a big tank like half of the fat bob tank it could hydraulic
Old Aug 25, 2012 | 07:10 PM
2011Deluxe's Avatar
2011Deluxe
Welcome!
Old Aug 25, 2012 | 07:27 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Welcome to the HD Forum from the sunny shores of SoCal.
Old Aug 26, 2012 | 09:37 AM
Jackie Paper's Avatar
Jackie Paper
Welcome from Hampton Roads Virginia...USA....Drain all the oil out. Refill it to correct level and run it about 5 minutes and shut it off. Recheck it for correct level. If it's way low there is something wrong with the oilpump. The oil pump is two pumps in one. One forces oil thru motor. The other one which is the bigger of the two returns the oil to the tank. If these bike sit a while and the oil that has collected up in the air filter runs down or you really turn them up to high rpm they will throw some oil into airfilter area and this is normal. Wrong oil filter can also cause problems keeping too much oil in engine. Could be your battery is worn out. Lot of little checks. if it ran OK when it was running it is probably OK. Just needs a little TLC and understanding
Old Aug 26, 2012 | 09:54 AM
tr8785's Avatar
tr8785
Welcome to the forum from NC!
Old Aug 27, 2012 | 09:02 AM
Longhair4life's Avatar
Longhair4life
Welcome
Old Aug 27, 2012 | 10:21 AM
3408pete's Avatar
3408pete
last weekend a sporty got fired for the first time in two months ----before he fired it he checked the oil level and it showed nothing.so he filled it to the high mark in the tank then tried to fire it and it ran a few sputters and tied up (hydro lock)before it was done it took a starter and a bag of floor dry .In his mind he had drained the oil and changed the filter but didn't add oil back.so my quess is it actually held twice the amount of oil minus a little -----it was funny especially since this thread was up
Old Aug 27, 2012 | 10:32 AM
ceebaileys's Avatar
ceebaileys
Former Sponsor
Welcome from sunny Southern California
dcarp444
EVO
19
Jul 26, 2019 08:50 AM
Derek Socalsinnershiner Matteson
Oil Archive (no new posts)
Apr 10, 2018 12:25 AM
Huskerjim
Exhaust System Topics
Oct 30, 2013 08:08 AM
lebert
Jun 23, 2012 07:09 PM
Mace
EVO
37
Feb 14, 2008 05:31 PM
