Wheel change
Old Aug 24, 2018 | 05:35 PM
Monty812's Avatar
Monty812
4th Gear
Default Wheel change
I've got a 2010 Ultra Limited w/Imperial wheels w/abs and I've bought the 2014 up Enforcer wheels and noticed they use a larger diameter rotor. What rotors do I need to get to work with my abs? Any help would very much appreciated.
Old Aug 24, 2018 | 09:55 PM
langwilliams's Avatar
langwilliams
the early V rod's used a semi floating 11.5" rotor for non brembro calipers. I have one laying around you can try if you pay the shipping. I lived in P'cola for several years while in the Navy. If you know someone with a machine shop you can take .3" off your rotors.
Old Aug 24, 2018 | 09:56 PM
langwilliams
also, when I put an enforcer on my 05 E glide I just bought Brembo calipers used off ebay.
Old Aug 25, 2018 | 07:40 AM
multihdrdr's Avatar
multihdrdr
First, the OP's post seems Odd ... (like a single -post Troll question )
Originally Posted by langwilliams
... (Stuff) ...
V-Rod Rotors, regardless whether they are the 11.5" or 11.8" versions are NOT the same as Enforcer Rotors.
The OP states he has 2010 Ultra ... He would already have Brembos (if he hasn't changed them)
Old Aug 25, 2018 | 11:29 AM
Monty812's Avatar
Monty812
4th Gear
My bike is all stock from Harley. I'm just wanting to change to a newer wheel. I saw a video on YouTube and the guy said that 08 and newer just used the enforcer wheel with the abs bearing and that's all that was needed except I had to also use the 11.8 rotors.
Old Aug 25, 2018 | 11:31 AM
Monty812's Avatar
Monty812
4th Gear
And I'm not how my post seemed odd like a troll? I'm on here for help not some spart *** who thinks hes the police!
Old Aug 25, 2018 | 12:22 PM
multihdrdr's Avatar
multihdrdr
Hmm ... interesting response from someone who's looking for Help
"I'm not how" (Is that "I don't know how" ?)... Because you don't know enough about what you're asking to know that your 1st post sounds like it could be interpreted as a Troll...
The ENFORCERS only came with 11.8" Rotors ... which is what your 2010 bike is set-up for ... (Rotors have nothing to do with ABS ... except for 2007-earlier Police Bikes)
You say you bought an Enforcer ... why didn't you just measure the Rotors? ... 11.8"
If your Enforcer didn't come with Rotors, then just get some 11.8 Enforcer Rotors (that's the STD size)
Just make sure you have an ABS Bearing in the Enforcer (Your bike has ABS) and then put it on ... That's it, nothing else needed ... No Magic
Make another one of your comments ... Next time you need help, it won't be me ... oh yeah, Welcome to the Forum
Old Aug 25, 2018 | 12:35 PM
Monty812's Avatar
Monty812
4th Gear
Thanks to those who past on the helpful information.
Old Aug 25, 2018 | 12:53 PM
multihdrdr's Avatar
multihdrdr
Thanks to those who past passed on the helpful information.
Hmm ... I guess that would be me?
Seeing as there was only one other poster and his info wouldn't be helpful for your Application
You're Welcome
partmann
Jan 9, 2018 09:37 PM
Cdal1
2014-2024 Touring Models
Mar 5, 2017 10:42 PM
StreetGlide515
Oct 22, 2015 07:15 PM
CSS899
May 19, 2015 12:24 PM
gartec81
Nov 26, 2014 03:51 AM
