If I put a 130/70/17 tire on the front of my ultra will I be able to notice a difference. I the current size is 130/80/17. Will it change the rake or mess with the abs.
Which brand of tyre are you considering? Check that the smaller section tyre has a suitable load rating for a heavy touring bike. IMHO you are most likely to discover that the lower section gives you a poorer ride, although that is not guaranteed.
ABS is calibrated for the diameter of the stock tires, change in tire size that is smaller/lager will have the ABS thinking there's a problem because the rotation ratio is off. Yes a lower profile tire will give a different ride. When I'm riding a Street Glide with a lower profile than an E glide I can tell the difference. To me it seems "busier" in that you feel more and smaller road imperfections that the higher profile tire sidewall absorbs. Some might say it gives a better feel of the road but I doubt many are riding close to the extremes where that additional road feel would assist in handling.
I am pretty sure this is NOT the case. The ABS is much simpler (and hence less error-prone), it only works off the ABS bearing. Plenty of threads on here that discuss this...
Best, niv
Yup, not sure why some people try to overcomplicate things by making stuff up....
Absolutely right! I think my mind was (is?) still obsessed with the pulley conversion I am planning, which does require such a readjustment... But the front wheel definitely does not deliver any information to the speedo 🙈
best, niv
