Wheel bearing help
Old Aug 14, 2023 | 06:39 PM
Woodrow Miller's Avatar
Woodrow Miller
Default Wheel bearing help
15 rg I’m doing all the wheel bearings in the rear and behind the pulley side is a .25
or so aluminum washer behind the bearing . The bearing was seated against the inner axle spacer on both sides snug so it seems it should be there just don’t see it on the rear wheel blow up for my bike. It just shows bearing going in. Is anyone familiar with the spacer and should I go back in? Thank you.
Old Aug 14, 2023 | 07:30 PM
GalvTexGuy's Avatar
GalvTexGuy
This same diagram was linked to in your other thread. It’s #6.
Old Aug 15, 2023 | 02:05 AM
Woodrow Miller
Default Bearing washer
The washer I’m speaking about was located between 3 and 16 in the diagram. It’s opening allowes the inner axle
spacer to go through it so the back side of the bearing seats to the axle spacer . Not seeing it on a diagram made me wonder
Old Aug 15, 2023 | 06:29 AM
jake24lt's Avatar
jake24lt
If you put the bearings in the wheel with just the sleeve,( no shim) the bearings should end up against the sleeve, If the sleeve is still able to move( side to side) and the bearings are bottomed out in their respective bores, either the sleeve is the wrong length, or something is off with the hub itself.
Old Aug 15, 2023 | 06:54 AM
Woodrow Miller
I am gonna go to dealer and see what they say it calls for on the microfiche but It seems wrong. Hope the pics help.
Old Aug 15, 2023 | 09:35 AM
multihdrdr's Avatar
multihdrdr
No, a bearing shim is Not used in your 15 RG (that's why you don't see it in the diagram).
But it didn't hurt anything ... The spacer sleeve sticks out farther (than the bearing bore bottom) than the thickness of the shim anyway.
Funny that "they" used a "FRONT" shim
Btw, is this an ABS bike?
Old Aug 15, 2023 | 10:19 AM
Woodrow Miller
Default Bearing shim
It's a non-abs bike. So, it makes sense now that the rotor side bearing seats in the hub while on the drive side the bearing stops at axle spacer and not seating in the bottom of the hub like rotor side.
Old Aug 15, 2023 | 10:34 AM
Jackie Paper's Avatar
Jackie Paper
Here is the theory behind it. All the axle torque goes thru the center race. One bearing bottoms. One sorta floats in the press fit where that inner sleeve stops it. Appears to me, someone has been in there who didn't understand something.
Does your service manual state which side goes first in to bottom?
A diagram although not yours may make this clearer. Just the first two. The last two are the old tapered bears that were shimmed to tolerance.
Old Aug 15, 2023 | 10:47 AM
Woodrow Miller
Default bearing help
The rotor side cavity is the depth of the bearing itself and the pulley side is deeper which is where the axle spacer comes through to catch the drive side bearing and not bottom out. And yes, someone definitely was in there that didn't have a clue. Thank you for the help to all that responded.
Old Aug 15, 2023 | 10:49 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by Woodrow Miller
... So, it makes sense now that the rotor side bearing seats in the hub while on the drive side the bearing stops at axle spacer and not seating in the bottom of the hub like rotor side.
Exactly
Harley made those "1st side" bearing shims (5 or 6 different thicknesses IIRC) to use for specific 25mm ID (15mm wide) bearing applications using wheels designed for the earlier 21mm wide bearings (3/4" & 1" ID).
BTW, they were used on the production line for 2008 Touring Mdls ... HD didn't redesign the wheels until 2009 so they used the earlier wheels with the "New" 25mm bearings and the shim for 2008.
You can see them in the parts diagram (front and rear)
For some reading reference:
Sealed Wheel Bearing Shims/Spacers - What they look like...Where they go
Lammy1000
2018+ Softail Models
Feb 1, 2023 10:46 AM
duderino420
Jul 29, 2021 07:43 PM
Xczar
Wheels/Tires
Apr 12, 2021 11:23 AM
1340fxrt
EVO
14
Nov 9, 2020 11:07 AM
1340fxrt
EVO
Nov 2, 2020 05:12 PM
