Brembo Brake Conversion
Old Mar 2, 2009 | 07:38 PM
Hodado's Avatar
Hodado
Default Brembo Brake Conversion
Hi
Has anyone put the Brembo brakes on any older models?I rode a new 2009 Streetglide last summer at a show in Ohio and could not believe the difference.No way I can have a new bike right now.Also if anyone knows of an economical upgrade I would like to hear about it
Thanks
Old Mar 2, 2009 | 07:45 PM
WVULTRA's Avatar
WVULTRA
Hodado:
Here's what I did:
http://www.box.net/shared/nhergtkq5r
Old Mar 2, 2009 | 07:55 PM
WVULTRA's Avatar
WVULTRA
You can do a search for "Brembo" in the Touring Forum. Lot of good reads there including this one:
https://www.hdforums.com/forum/touri...onversion.html
Old Mar 2, 2009 | 07:59 PM
Hodado's Avatar
Hodado
Thanks for file.Two questions:How much $$? Were the results worth the effort?I gotta believe if it helped you get out of one jam it must be yes
Old Mar 2, 2009 | 08:12 PM
WVULTRA's Avatar
WVULTRA
As I said in the above post:
One of the best OEM braking sytems I've ever encountered on a Touring bike!
A simple parts swap if you've got the '08 components.
Costs are totally dependent on how savey a buyer one can be. There's some good links in the above post to give you an idea of what's involved.
Again, good luck!
Old Mar 5, 2009 | 04:53 PM
02Ultra EG's Avatar
02Ultra EG
Default Brembo conversion
Did this change on my '02 Ultra. One of the best things I have done. Bought all my parts off E-bay. You can probably get all the parts for $350-$500. Just make sure you use all '08 parts!! Good luck.
Old Jan 20, 2012 | 03:42 PM
oldguy101's Avatar
oldguy101
Default Brake Conversion
There is a PDF from an old post that covers it in detail here:
http://www.box.com/shared/uezic40eyp
Did it on my 07 ultra, found most of the stuff on ebay. Worked well.
Old Jan 29, 2012 | 02:01 AM
mglax13's Avatar
mglax13
I just did a handlebar swap and added a +4 brake line. Do I need to change this brake line if I were to do this swap, or can I keep the current brake line?
Old Mar 9, 2012 | 05:01 PM
marvincbr's Avatar
marvincbr
I did this swap on my 07 RG, but am having trouble getting everything to work correctly. The brake lever will come all the way into the grip if you hold it long enough and eventually the caliper/pistons will release the rotor and the wheel spins. Does this sound like a bleeding issue? Is anyone else that did this change out having any problems? Thanks
Old Aug 27, 2014 | 04:30 PM
Roadglide Mike's Avatar
Roadglide Mike
Default Wvultra
Why does it have to be a 2008. Ive read around that the 2008-2013 have the same lower fork legs and rotors just two variables being either AABSor NON-ABS. I have a 2003 Ultra and I did a 18" front wheel swap on my roadglide before I sold it. The 2001-2007 rotors are 11.5" 2008+ are 11.8". I already have the brembo rotors and I just picked up a 2013 master cylinder. Will the 2013 master cylinder not work on my 03?
Rock Chalk
Stock Harley Take Offs
Jul 24, 2016 03:44 PM
Rock Chalk
Dyna Parts
Jul 12, 2015 07:46 PM
NE TSPORT
Jun 28, 2014 06:45 AM
CrusinLum
Jun 26, 2013 10:06 PM
FL-kruzen
Dec 8, 2012 05:44 PM
